Post #212
Any of the 255 L/PH pumps should be OK - there are some minor differences in the inlet/outlet loacations but it should make much difference.
Just get one with a universal fitting kit.
From experience, thinking about it, you would be best of getting an external one, and run it inline with the OE one still in the tank. Either that or run a swirl pit with Walbro pump.
I use to get fuel surge with a Walbro pump shoe-horned in to the OE casing, this is becuase the standard pump has an anti-surge valve built into its inlet which the 255 L/PH pumps dont have.
I did make a mini anti-surge resevoir and bolted it to the pump casing, that helped
TBH the above isn't a problem apart from on track, and if you keep plenty of fuel in there that solves the problem too.
Anyhow, here's the Walbro pump sho-horned into GTi-6 casing, with stainless anti-surge resevoir which was later added..
And here is a full blown swirl pot setup with external pump...
Contact Details:
07732 822546
