Post #97
There's plenty of intercoolers out there that will fit, or can be made to fit..
The most important thing is the outlet positions, these both need to be downwards facing, so the pipes can run under the chassis cross-member and back up into the engine bay.
If you want to keep the standard fan cowling/fans, stick to a 2" thick core, and depending on the size of the cooler you should only need to remove minimal material from behind the bumper.
Thicker cores will require the removal of the OE fan cowling, and use of slimline fans such as SPAL, Kenlowe etc.
The Derv Doctor to a nice little 2" thick intercooler they use on tuned 306 DTurbo's, which has the downwards facing outlets and would be ideal for this conversion.
Another option, but expensive, is the Pace Products 306 DTurbo charge-cooler kit.
If you want to pick up a universal cooler and make it fit, eBay is the best, check out eBay US too - 1000's on there, and they're very good, and very cheap too. You will get stung on the shipping but it can still work out considerably cheaper than the UK.
Contact Details:
07732 822546
