displaying posts 101 to 115 of 115
Pages (5): first .. 3 4 [5]
Author Subject: Group buy oil catch tanks
rallyestyle
Post #101
I keep coming back to this and im still confused as to whether i should get a catch tank, which of these two types i should be looking to get, and if there is a proper method of install LOL Doh
Just Drive It
Posted 2nd May 2014 at 15:38
demondriverdan
Post #102
Similarly, any recommendations on what to get for the race car?
Rallye Race Car
Posted 2nd May 2014 at 18:15
Post #103
Know this is a old thread but did anyone decide what's best on fitting one ...just bought a 1litre Mocal catch tank is blanking the inlet manifold best & using filter on Mocal & do you use one way disc from rocker cover to catch tank ???
Coskev said something about needing suction into the catch tank ?....do I connect from catch tank to inlet manifold as Stnd but with Catch tank inline ????
Hopefully fitting tonight ?Smile
Posted 15th Apr 2015 at 09:47
demondriverdan
Post #104
I bought one off eBay, fitted pipe straight from rocker cover into the tank and put a breather on the inlet. That's probably the wrong thing to do though Smile
Rallye Race Car
Posted 15th Apr 2015 at 09:57
Post #105
Really you need one like I have which has an inlet and and outlet pipe but with a breather on the top of the catch can. Let's the vapours out but still let's it suck through from the inlet. However I've not had the outle pipe connected to anything sing going supercharged and it still fills itself up with condensation water. Every month or so there's probably 25ml of slightly oily water in it I have to empty. So it's obviously still doing the job well enough.
Posted 15th Apr 2015 at 10:30
Post #106
Just got off the Phone to Miles & he said blank inlet & run pipe from rocker to catch tank & pipe from second feed to close to bottom of the engine bay because of fumes from pipe getting sucked into cabin ....you don't need a filter !!!
I'll take some pics later !
Also don't use one way fitted stnd !
Hope that helps ?
He said if oil does go into catch tank it's a build up of pressure & it should only be Vapour with misty oil at worse ???
Posted 15th Apr 2015 at 10:36
Post #107
Just fitted mine & the vented outlet goes behind Ecu &
down below steering rack & vents out below car Thumbs up
Blanked the inlet pipe on manifold !
Posted 15th Apr 2015 at 20:36
Post #108
Now I've fitted above the car ticks over much better funny that ?
Noticed Stnd pipe was split ...maybe I sorted a problem I didn't know I had ?
If you look closley on the left ...The pipes split !!!!
Posted 15th Apr 2015 at 20:40
midlife
Post #109
From the regs I've seen, you don't need to use an oil catch tank for motorsport, but if you do have one it should have a capacity of two litres.
Luckily I have just the thing for sale if anyone is interestedDunno
Mocal 2ltr oil catch tank, brand new £95 delivered
http://www.rallynuts.com/oil-catch-tanks/mocal-2-litre-bulkhead-mounted-oil-catch-tank.html
Cool
Team 330™Cool
Team "no front end or engine"
Posted 15th Apr 2015 at 21:21
Post #110
Wayne that's cheap they are £125 @ MerlinThumbs up
Rallynuts are cheap !!!
Posted 15th Apr 2015 at 21:28
midlife
Post #111
Yes I know, I've had it up for sale for ages at £105 with no interest so I've dropped it a bitThumbs up
Cool
Team 330™Cool
Posted 15th Apr 2015 at 21:43
Mossy1985
Post #112
If i knew what it did i might be interested lol apart from catching oil lol
Posted 15th Apr 2015 at 21:47
midlife
Post #113
The catch tank separates the oil mist & crank case pressure from the induction side of the engine.
It gives the engine a clean air/fuel mixture to burn, I believe it acts like running on higher octane fuel.
Cool
Team 330™Cool
Posted 15th Apr 2015 at 21:57
Post #114
Cool
I believe your spot on Unsure ......my car seems to tick over & run better now Crazy
Posted 16th Apr 2015 at 05:58
midlife
Post #115
Well that sold quickly!!!
Cool
Team 330™Cool
Posted 16th Apr 2015 at 06:04
