displaying posts 76 to 100 of 115
Pages (5): first .. 3 [4] 5
Author Subject: Group buy oil catch tanks
x69 rgg
Post #76
puglover wrote:
rallyestyle wrote:
So has it actually been decided which tank is best and how best to fit it? Do we need one with a filter in top or is that really surplus to requirements?
the mocal ones are the best and u guessed it the most expensive. They have a patented filter/breather on the top which is designed to let it breath but hold some back pressure. They also look a million times less tacky than any others ive seen.
interested. mocal? this fit?
clicky
"I need to 're-mortgage' my six"
Posted 7th Jun 2009 at 03:31
jose
Post #77
Got mine off ebay! Its collected some interesting fluid to say the least, did have a photo but it was on my old phone Sad
Nile Blue GTi6
Alpine White 205 GTi 1.9 - Project
Air Con Pipes Thread.......
Machine Polishing - Paint Correction - Swirl Removal in West London - PM for details
Posted 11th Jun 2009 at 00:37
dan86
Post #78
I like the look of Jose's catch tank- it looks almost OEM. I need to get one on mine as my K&N is getting soaked! would the ECU compensate for any air/fuel ratio change from blocking off the mani inlet/feeding it cleaner air from a vented tank?
Posted 12th Jun 2009 at 03:13
iplay
Post #79
Posted 30th Jun 2009 at 08:56
iplay
Post #80
How does it fix to the car?
and where did you get the piping from?
Posted 30th Jun 2009 at 09:13
jose
Post #81
Hi, Thats the exact one i have, think i paid about
Nile Blue GTi6
Posted 30th Jun 2009 at 21:31
Post #82
the pipe on the right hand side of the 2, on the rocker cover, it splits into 2 a bit further down, can anybody tell me if these are both breathers and if it would be ok to take this straight to the catch tank aswell as the one from the rocker cover??
thanbks
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 14th Jul 2009 at 03:03
Post #83
Sorry to bump this thread, but is the above the correct way to fit?
Seems good to me, but what about a filter, is one needed?
Does anything else need to be done that can't be seen in the picture?
Posted 11th Nov 2009 at 21:02
iplay
Post #84
PhillipM advised to attach it after the regulator (one way valve thing).
Posted 11th Nov 2009 at 22:19
vts_tibi
Post #85
I have the same oil catch tank, and it looks great!
Mine is on from Spetember, and there's absolutely nothing in it... but I think it will has a function once I get onto the track.
sorry... shite pics...
VTS
best 60' : 2.272
Team Trackday™
Posted 14th Nov 2009 at 21:33
beez_neez_gt
Post #86
Very nice but the filter iv read can muck up the engine bay a treat, im going to do the same as above apart from having the filter on the end of a pipe going down the front of the engine tied up, the smell will go under rather then into the cabin. Then just block off the inlet outlet.
This negative pressure seems odd when the inlet air ie oil vapour goes into the bores anyways. So it'll just go into the tank and the filter will be like as if it's going into the bores.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 4th Sep 2013 at 05:38
beez_neez_gt
Post #87
Mine is now fitted and it has definitely made a difference in power, well worth it IMO.
Not only has the oil vapour gone but this vapour would also be warm, so effectively it has made the incoming air cleaner and cooler, can't recommend this mod enough, noticeably more power and will see by how much when I have another rolling road test done, last one came at 174.7 BHP two weeks ago.
Although I still have to fit the new alu rad to make engine nearer to the ideal 83 c temp where that temp makes these engine's perform at their best.
Ill do a thread with all the info soon.
Pug fee`ver,
Posted 9th Sep 2013 at 16:56
3rd time lucky
Post #88
I like the sound of that. Cant wait to see the results Smile
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 9th Sep 2013 at 17:25
Post #89
The trouble is with having no vacuum draw of the crankcase gasses is that you are relying on blow by pressure to push out the fumes/moisture etc.
On a nasp engine you do not get much blow by.
Race engine's get away with it due to the temps the oil gets too and also regular oil changes.
A road car engine will not get hot enough on every trip to evaporate moisture from the crank case and it will end up collecting in your cam covers.
A oil seperator is the best bet,that seperates liquids and retains them in the can,and the gasses get sucked into inlet.
Since fitting mine the tb/inlet is oil/gunk free, and I have got about half a jar full of water/gunk out the seperator after aprox 6 months use.
Run a empty catch can with no vacuum draw for 6 months and see what you get in it!!! Not alot is the answer as the moisture/gunk is in your crank case still mixing nicely with your oil!Yes
Posted 9th Sep 2013 at 18:49
beez_neez_gt
Post #90
Good job these are fitted with a windage tray then lol. Car has regular oil changes anyway. My oil always gets too 100c and use ester oil to help cope with these temps, I dont use an oil cooler yet and if I did id use a thermostat type. Engine has done 40k in its life.
Engine running there is plenty of smells coming from the filter strapped on underneith, I will check the tank regularly though. I might get some mesh inside the outlet tank connection bit. Tank is also a small one.
So what would you suggest, I fix the filter pipe to the inlet section, this would defeat the whole point of it though.
Oil or water dont actually pour into the pipe, just vapour and since I can small and feel the air coming through the filter this should be enough. This vapour when inside the tank it should make it condensate and collect it.
Pug fee`ver,
Posted 9th Sep 2013 at 19:29
beez_neez_gt
Post #91
Do you mean something like this >
http://www.ebay.co.uk/itm/Sealey-ILF-SE-In-Line-Water-Oil-Trap-Filter-Seperator-/360403889574?pt=UK_Air_Tools_and_Compressors&hash=item53e9beeda6
or this >
http://www.ebay.co.uk/itm/group-A-oil-breather-seperator-suit-race-rally-or-track-car-cosworth-evo-etc-/121172346130?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c366f4512
http://www.ebay.co.uk/itm/Alloy-oil-breather-seperator-catch-tank-short-circuit-autograss-off-road-/151118807883?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item232f62034b
Then pipe up the outlet pipe to the inlet with the filter within this line ?
Pug fee`ver,
Posted 9th Sep 2013 at 20:50
Post #92
It woukd defeat the object connecting the empty catch can to the inlet yeah, but not a proper seperator that has seperated liquids from gassesThumbs up
These work really well:
http://www.saikoumichi.com/OCC_explanation.htm
Not cheap but you do see the results when you drain itYes
Used a cheaper one on rallye off e-bay:
http://www.306gti6.com/forum/showthread.php?id=148753
Got loads of gunk in it when running 10w40 semi synthetic,half as much now running 5w50 fully syntheticThumbs up
Posted 10th Sep 2013 at 06:36
beez_neez_gt
Post #93
Looks good, cant see where or how to buy the first one and the second one isn't on sale anymore.
Pug fee`ver,
Posted 11th Sep 2013 at 07:05
beez_neez_gt
Post #94
Found this but still no prices http://www.saikoumichi.com/
Pug fee`ver,
Posted 11th Sep 2013 at 07:20
Post #95
Try putting your glasses onThumbs up
http://www.saikoumichi.com/price_list_reference.html
Posted 11th Sep 2013 at 08:40
beez_neez_gt
Post #96
Glasses LOL more like x-ray vision. Iv had another look been on every link I found but no prices lol.
I like this one and when converted is about £45
http://www.saikoumichi.com/micro_oil_catch_can_tank.htm
But need a closer look later for the right size etc.
Pug fee`ver,
Posted 11th Sep 2013 at 08:55
Post #97
I got that from your link above! Roll eyes
Right hand side of page, 2013 price listThumbs up
Posted 11th Sep 2013 at 09:01
beez_neez_gt
Post #98
Yep spotted it now, thought it would be a highlighted link for easy use lol.
Have you got one and if so whats it like and which one did you buy ?
Pug fee`ver,
Posted 11th Sep 2013 at 09:11
Post #99
Yeah used the twin one on Evo as they run two breather outletsThumbs up
http://www.saikoumichi.com/DC3_page.htm
Just joined a group buy on Briscoda for a single can one with sight glass and 19mm outlets for my VRSSmile
The one on Evo worked really well,but a turbo charged engine does breath more than a nasp due to the forced air passing piston rings.
Posted 11th Sep 2013 at 16:28
beez_neez_gt
Post #100
Well iv had my standard oil catch tank in for a good few weeks now with use of the car 2 or 3 times a week not a daily driver.
Here are a few pictures of what mine has been like during this short time, seems very different to your experience and i'm not quite sure why, maybe its because my engine had done very few miles during its lifespan Dunno
Here is the cam outlet with no mayo >
Here is the catch tank inlet with the mayo >
Here is the catch tank fluid amount, tank is at a slight angle to show just how much mine has collected up during this short time. basically the fluid has come up to the lowest part of the amount showing pipe in picture >
Even with this I have now fitted the small oil/water separator catch tank which looks neater, it just goes to show these standard oil catch tanks can work just as well without the inlet air feed Yes
Pug fee`ver,
Posted 24th Oct 2013 at 08:38
