I dam well know the feeling of put on / take off Etc
| Author | Subject: 306 Maxi project |
Post #201
Looking great Iain I dam well know the feeling of put on / take off Etc |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,887 Status: Offline |
Post #202
quote: [quote RallyeRed]When Dave's sorted the front wings, Hopefully not too long now! ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
Post #204
Think I’ve figured out now the outlet on the left of the plate is the side that flows to the cooler.If someone could confirm that’d be great. |
Post #205
I'm not 100% sure but i think you're right. The filters have a perforated metal tube runs down the middle, i've always assumed this holds the filter material in place so it doesnt try and collapse in to the return which would be the centre hole. I hope that makes sense.Nice work on the project so far by the way ________________________________________ Goldie the track car. |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
Post #207
I can look tomorrow or Tuesday night unless anyone let's you know beforehand. I have mine done in braided hose to a 106 pump so must have worked it out when I did that!Out if curiosity, was there a reason you had the adapter tigged up rather than use an off the shelf adapter? |
RallyeRed
Post #208
Not really Martin; I didn't know the female thread of the widget that goes in the pump, and because the steel bosses are peanuts and I knew I could get it tigged on for nowt, it was just a cost effective way to do it. (And I guess one less join to seal)If you could let me know the score on the high pressure inlet on the rack, when you get to your car that would be much appreciated. All of my 'before' photos don't quite answer my question! Cheers Iain |
devere
Post #209
Finally managed to have a look at the car. I have the at high pressure inlet at the top and the return as the lower hole on the rack. Must be right as mines been working for a while! Haha |
demondriverdan
Post #210
Iain, how difficult was it to make your own PAS and oil lines? I'm not sure on the process involved to fit the AN fittings?________________________________________ Rallye Race Car |
gnrlee
Post #211
this might help Dan Making AN Fittings Youtube Vid ________________________________________ Proud Member of the ASTOR Owners Club |
devere
Post #212
quote: [quote="demondriverdan"]Iain, how difficult was it to make your own PAS and oil lines? I'm not sure on the process involved to fit the AN fittings? there are plenty of guides about like linked above Dan. I made my fuel lines and PAS lines and id never done it before. I bought the bits from Torques and a step by step guide was included with the fittings. |
demondriverdan
Post #213
Cheers guys ![]() ________________________________________ Rallye Race Car |
RallyeRed
Post #214
quote: [quote="devere"]Finally managed to have a look at the car. I have the at high pressure inlet at the top and the return as the lower hole on the rack. Must be right as mines been working for a while! Haha Thanks for that Martin - I guessed lucky then! (Relief...) PAS |
RallyeRed
Post #215
Dan, the method varies depending on the hose.PTFE lined stuff for higher pressure applications like brake, clutch etc (and also fuel lines) which I used for the PAS work by inserting the PTFE part of the hose in an olive, and the female fitting (red part on Goodridge) clamps over the braided covering and tightens down on to the male male of the fitting. You just have to be careful the hose doesn't get wound out of the fitting as you tighten it up. For oil lines Goodridge use a cutter style male fitting which bites into the hose lining as the female fitting is tightened up, and doesn't use an olive. It's critical the right types of fitting correspond with the intended hose and function. I've attempted to use Torques stuff in the past along with similar Ebay fittings and been left disappointed but their quality and function. It's personal choice, but despite the significant cost savings, it's not for me. I'll stick to Goodridge and Speedflow. The Speedflow stuff I used on the oil cooler is push on style. It's the first time I've used it, so the proof will be in the pudding, but it was childs play to fit, and I was impressed with the quality. Generally I used Goodridge type of self assembly (and re-useable) hose and fittings because I'm exploring different fit, and routes or there's some form of custom requirements. It's very expensive, but along the way I've been able to dive into my parts boxes from other builds to make up what I need, as well as buying some new stuff too. Making up the hoses just offers me the flexibility of sizing or routing things differently and making up the hose on the spot to fit. It only takes moments once you know the lengths etc. Many suppliers offer their own hose making service, but you'll need to be sure about the right ends, and exact lengths etc. Making up the hoses often comes at little extra cost - all the cost comes in the parts. |
demondriverdan
Post #216
Cheers Iain, appreciate the write up!________________________________________ Rallye Race Car |
blandy
Post #217
Have you got any more pictures of your lower rad hose set up? After mocking up rads I've decided to go 205 as I have all from my 205 - apart from the bottom hose |
RallyeRed
Post #218
All in post 182 mate - Spoox 306 hose to 135deg hose with a 32mm joiner |
jonbb
Newbie Location: pamplona Registered: 01 Jul 2017 Posts: 21 Status: Offline |
Post #219
Hola tienes fotos de como vas a ensanchar ejes?mover copelas trapecios o brazos y mangueta o pivote? |
jonbb
Post #220
El mio pide ensanchar 11cm por cada lado en la parte delantera |
blandy
Post #221
quote: [quote="RallyeRed"]All in post 182 mate - Spoox 306 hose to 135deg hose with a 32mm joiner ![]() |
Post #222
quote: [quote="blandy"]Have you got any more pictures of your lower rad hose set up? After mocking up rads I've decided to go 205 as I have all from my 205 - apart from the bottom hose pull the metal bit off the end of a 306 hose, I think that will go straight on a 205 rad with a hose clamp, mine goes onto a small manifold thing to tee off to the header tank and the heat exchanger. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #224
no need to cut the abs loom, its all self contained and you just need to remove it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jonbb
Post #225
Hola felicidades por el maxi. Me podrías ayudar con lo de la suspensión pivot etc? Las copelas las has movido? Tienes separadores? |
