Author Subject: Exhaust Sealent
oliverharveyuk@hotmail.co.uk
I have never fitted an exhaust before and looking to replace the full system from manifold back, any recommendations on exhaust paste? I've read that paste is rubbish and will go brittle and fall away so to use silicone, but apparently this can have an effect on the lambda sensor?
98 Blaze 6 - Current
Posted 15th Mar 2017 at 14:22
mocinim
Holtz or car plan there much the same they both work fine every time for me
No paste at the cat engine side just a new gauze gasket n kit (dont crush the springs )
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 15th Mar 2017 at 15:53
Holtz stuff is crap and cracks eventually!
Just buy clear silicone sealent from Wilcos etc
That does a cracing job!
Posted 15th Mar 2017 at 17:54
For god sake don't use silicon on mild steel as it will corrode it crazy quick ...use it on stainless Yes
Posted 15th Mar 2017 at 18:50
Ive never heard of silicone desolving mild steel??? Confused
Edit: justchad a quick look into this you can get acid etch based silocone which is a bad idea
polyurethane based seems to be ok to use, and the brand of choice seems to be Sikaflex ill look at the wilco stuff I use is
A polly type but ive never had any corrosion and ive been using this method for about 7yrs Dunno
Posted 15th Mar 2017 at 19:06
A lot of silicone cures via an acidic reaction so it can corrode the steel surface. But frankly it's an exhaust that's probably already corroded as feck anyway Big grin
Polyurethane doesn't resist the temperature like silicone, most automotive sealants are very low on the acid cure anyway as they are intended to be used on steel and alloy, unlike the bathroom sealant types - hence the really acrid smell from the bathroom stuff vs gasket seal versions. I've never had an issue using automotive silicone on exhausts tbfh.
Posted 15th Mar 2017 at 19:20
I should of said don't use bathroom Silicon Thumbs up
I've used Wurth Automotive Silicon sealant which are great but cheap bathroom Silicon sealant will cause you issues Thumbs up
Posted 15th Mar 2017 at 20:09
So I should go for automotive silicon? Didn't realise it would be so technical... Would this be okay?
sealent
Posted 15th Mar 2017 at 19:54
sealent
That looks spot on Thumbs up
Bathroom silicon should only be used on metal bathroom items that are plated...e.g. Chrome / Nickel / brass etc
Posted 15th Mar 2017 at 20:11
