Any ideas? Bit stumped on this one
Rallye Race Car
| Author | Subject: Soft brake pedal even after loads of bleeding |
demondriverdan
Not sure what to do on this one. I replaced the brake lines in a car with copper and the brake pedal has never been very good. I've bled all 4 brakes a few times (putting nearly 2l of extra fluid through the car) and even tried replacing the MC but it still isn't great. I want the pedal to feel harder, like you can really push it as you can in my race car.Any ideas? Bit stumped on this one ________________________________________ Rallye Race Car |
has it got a load compensator?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
No, only bias valve________________________________________ Rallye Race Car |
aaron6
What fluid you using as i got a similar kit to yours and my pedals is spot on.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
demondriverdan
This is a standard setup, it's not on my car. Mine is absolutely fine ![]() ________________________________________ Rallye Race Car |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
If the car has abs I would suggest air is trapped somewhere. You can try and take it to a loose surface car park and cycle it a few times, drive about a bit, bleed again. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
demondriverdan
No ABS, new copper piping throughout________________________________________ Rallye Race Car |
Ben_W
Formerly gpm Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,941 Status: Offline |
There's either air still in it or its leaking somewhere......just out of interest, how old was the fluid you put in? ________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
demondriverdan
Brand new, no point putting old fluid in a car! I'm going to drain it all and try a different fluid, see if that sorts it. There are no leaks as far as I can tell. All very frustrating!________________________________________ Rallye Race Car |
What calipers are on it? Are you pressure bleeding or using the pedal? ________________________________________ Nothing to see here |
demondriverdan
Standard all round. Tried both methods, still no luck________________________________________ Rallye Race Car |
I would check all the connections are good, nip them up. Check the rubber hoses are good and aren't bulging. Check no leaks from calipers. Bias valve the right way round? I'd use it, get the brakes hot and cold a few times. Bleed using the pedal. Might just need cycling through ________________________________________ Nothing to see here |
demondriverdan
Cheers Adam, will do all that ![]() ________________________________________ Rallye Race Car |
I usually get bleeding spot on but after upgrading the rear brakes on my leon to larger vented cupra r setup there was clearly air still in the system. Wouldn't Bleed out no matter what. Drove it about a couple of days with shocking pedal then bled again amd loads of air came out the rear lines. Rock hard pedal again. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
jord294
My opinion is new brake fluid has perished seals in M/c slightly.Had this experience on 2 previous cars. If doing new brakelines, I tend to use pipe with kunifer, as copper is too soft ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
new fluid wont do that, the rubber is brake fluid resistant, its just worn out.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jord294
I beg to differ mei________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Would imagine its both the rubber composition is altered due to age wear n contamination and the new fluid has attacked it being neet and corrosive ?? ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
pete_rallye
Seasoned Pro Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
Its a new master cylinder though isn't it? The rubber shouldn't perish that quickly. You still got the servo? If the servo is f**ked you never get the full vacuum effect which can cause pedal to feel soft even though it isn't. There isn't an 'up and over' bit in the pipe anywhere that could trap air is there? Is it a standard master cylinder? If you completely empty a master cylinder they can be a b**ch to get the air out of. My old Volvo V70 did this so one day I sat there and just pumped the brake pedal about 50 times and the pedal slowly came back again. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
mocinim
Its bad design really my old vw bora had a bleed valve on the pump block saved so much grief ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Get anywhere with this?________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
