Author Subject: Dealer says BV 75w80 is superseded by...
mik
...some sort of Mobil 75 single viscosity oil that says on the label that it replaces, and will provide superior fuel economy to, the BV 75w80 and is suitable for all PSA vehicles manufactured in Europe. It has a Peugeot/Citroen logo on the bottle, and I had this discussion at a Peugeot dealer.
Now I do recall discussions some time ago that the gearbox on these cars is sensitive to the gearbox oil used, and the factory stuff was the best. But this official replacement is a different viscosity to the one originally specified for these cars. The only other thing he had was a Nissan 75w80 gearbox oil.
I'm thinking that the single grade will be thinner when hot, probably where the claimed improvement in fuel economy comes from. I'm wondering how will this affect a 120K mile gearbox?
Has anyone else had this conundrum, and if so what did they do. I warned him I'd take advice and might bring it back.
Cherry Rallye SOLD
Posted 9th Sep 2016 at 13:33
itll be fine, used some recently in an used box with a quaife, only noticed that its slightly thinner and not stinky.
Posted 9th Sep 2016 at 13:58
its the additives in other oils that cause issues, the new o.e oil is intended for all be boxes.
Posted 9th Sep 2016 at 13:59
jeffers Forum Admin
This new stuff is absolutely fine, put it in mine last year and it's spot on.
Team Running Engine again!
Team Negative Camber!
Posted 9th Sep 2016 at 14:11
oh and total still do loads of 75w80 bv oil if there are any motaquip factors in the area
Posted 9th Sep 2016 at 14:13
mocinim
http://www.ebay.co.uk/itm/Total-Transmission-Gear-8-75W80-Manual-Gear-Box-Oil-2L-/181856223469?hash=item2a5779c0ed:g:yFoAAOSwu4BV6AFC
This is what i use works really well lovely smoothness in the box
I believe its the same as the pug supplied stuff
This gear 8 is the replacement for the BV stuff
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 9th Sep 2016 at 16:06
This. Yes
Works great in mine.
Posted 9th Sep 2016 at 20:01
mik
Excellent, thanks all for the responses. I'll put it in the car on Sunday, along with some Millers CFS 10w40 ester synthetic for the engine. I even remembered to get two sump plugs, as I've forgotten to get an extra one for the gearbox plug the last couple of times (hoping it is the same size as the engine one).
I'll follow up on the motaquip tip as well, forgot that they do some OE-spec stuff for PSA cars as a mechanic told me when I first got the Rallye.
Cherry Rallye SOLD
Posted 9th Sep 2016 at 20:04
deeturbo
Engine sump plug washer and box plug washers are different sizes. The box one plug is larger, I found this out after removing the plug and dropping the oil Sad
Posted 11th Sep 2016 at 18:36
demondriverdan
I also don't think you can just buy the gearbox plug washer from the dealers, only the entire plug. Think it's only £7 or something though
Rallye Race Car
Posted 11th Sep 2016 at 18:37
deeturbo
Engine sump is 14mm and box is 16mm.
Posted 11th Sep 2016 at 18:40
deeturbo
Yep this. Just seen on service box.
Posted 11th Sep 2016 at 18:41
scotzman
205 sump plug washer is 16mm
Posted 11th Sep 2016 at 20:03
mik
Thanks.
Cherry Rallye SOLD
Posted 12th Sep 2016 at 04:17
