The gearbox oil from Pug is now 75w rather than 75w80.
Has anyone tried the 75w and is there any noticeable difference in gear selection, smoother?
| Author | Subject: 9730 AA to 9730 AG Gearbox oil |
deeturbo
Regular Location: Leighton Buzzard Registered: 22 Feb 2003 Posts: 283 Status: Offline |
Hi,The gearbox oil from Pug is now 75w rather than 75w80. Has anyone tried the 75w and is there any noticeable difference in gear selection, smoother? |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
yes I am using it i've noticed no change |
deeturbo
Have you used it over winter to? |
cully
no only since ive fitted the ATB in june |
deeturbo
I wonder what the reason for them to change it was? |
more mpgz.its still the right spec for the synchros etc, but a bit thinner and less stinky ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
deeturbo
Talking about thinner oil, I'm running 10w40 at the minute in the engine and I've changed a lot of seals as some were weeping. With the better seals I should be ok to run thinner oil without the issue of leaks.I was thinking of using 5w30, is it ok to use for normal road use in these engines and should I see a slight increase in MPG with it? |
deeturbo wrote: Talking about thinner oil, I'm running 10w40 at the minute in the engine and I've changed a lot of seals as some were weeping. With the better seals I should be ok to run thinner oil without the issue of leaks. I was thinking of using 5w30, is it ok to use for normal road use in these engines and should I see a slight increase in MPG with it? Oil wont increase MPG and i'd be sticking to 10w 40 myself on a standard car |
cully
GTI6 is not about MPG!Smiles per mile is my aim |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
I use 5w30 in my black rallye had it rebuilt and only use it at night Helps a little with cooler temperatures But for daily id use 10w40 or 5w40 in winter W30 is to low for general use especially if its your daily ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
deeturbo wrote: Talking about thinner oil, I'm running 10w40 at the minute in the engine and I've changed a lot of seals as some were weeping. With the better seals I should be ok to run thinner oil without the issue of leaks. I was thinking of using 5w30, is it ok to use for normal road use in these engines and should I see a slight increase in MPG with it? 10w40 semi is the correct oil for these engines so why would u want to change? ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
deeturbo
Oops meant 5w40, Total QUARTZ 9000.My thinking was slightly thinner oil being easier for the engine to pump round. |
deeturbo
I do like to keep an eye on MPG as it does tend to show up some issues early.At the moment I'm getting 35mpg on spirited drive to work. It's a shame it motorway mostly and not country roads like it used to be. |
