Author Subject: 2 refurbished Gti6 rear beams.
gretsch-drummer
I have 2 beams I've just refurbished up for grabs. Both have been fitted with new shafts, bearings (45 needle outer) and seals. I've brush painted them with hammerite (my old beam I refurbed 2 years ago with hammerite seems in better nick' than my powder coated spare wheel as that has starting to show signs of rust!). For the ARB seal I used rubber o-rings as the Peugeot foam type seems to go solid and fail.
SOLD £250 SOLD
£225 - missing heat shields and 1 arb plate plastic cap.
(Thats grease on that shaft, I forgot to take the picture before starting to build it up)
Collection from Cookridge, Leeds.
Ph1 Cossack 6'
Posted 25th Aug 2016 at 11:23
aussiepug
Hi - mind telling what O rings you used for the arb. I was about to go and buy standard seals.
John
Posted 22nd Jul 2016 at 04:02
not had problem with standard seals.
Posted 22nd Jul 2016 at 07:35
Nice job! what did you paint them with? Just rattle can or powerder coat etc?
Posted 22nd Jul 2016 at 08:19
jord294
Hammerite
Posted 22nd Jul 2016 at 08:31
Thumbs up looks spot on i'll have to paint mine!
any undercoat used?
while you're here Jord I bought a Xsara VTS rear beam but it weighs a hell of a lot more than an standard 6 surely that can't just be from bigger torsion bars?
Posted 22nd Jul 2016 at 08:36
more rust.
Posted 22nd Jul 2016 at 09:21
LOL they were rebuilt just before I bought them!
I just noticed the difference when it come to swapping them over!
Posted 22nd Jul 2016 at 09:29
jord294
306 and xsara a pretty weighty compared to 205/309
If the xsara axle is heavier, it's only marginal
Posted 22nd Jul 2016 at 14:46
405 / partner / xsara Picasso are hefty units, 106 are positively lightweight compared to them!
i can't lift them, where i can easily walk the length of a scrapyard with a 306 beam O_o
Posted 22nd Jul 2016 at 15:33
gretsch-drummer
The £250 beam is Sold.
Ph1 Cossack 6'
mocinim
Is postage possible chap
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 27th Aug 2016 at 16:11
gretsch-drummer
If you arrange for a courier to pick it up then no problem.
Ph1 Cossack 6'
Posted 27th Aug 2016 at 20:10
jord294
SOLD £250 SOLD
Whatever you do, don't build anymore!
Posted 6th Jun 2020 at 15:50
lol
did you get one to fix Andy?
Posted 6th Jun 2020 at 15:54
