displaying posts 1 to 25 of 39
Author Subject: Bad tapping from engine
finnie
Hi all,switched car off and went into shop,came out and started it and it was running like a bag of bolts and a really bad tapping noise which sounds like it's coming from top end,car has no power either now.any ideas to point me in the right direction
Moonstone gti6
Posted 22nd Apr 2016 at 07:38
jeffers Forum Admin
Timing belt slipped?
Team Running Engine again!
Team Negative Camber!
Posted 22nd Apr 2016 at 08:27
superchargedblack1997gti6
Video may help mate?
Posted 22nd Apr 2016 at 09:40
mocinim
Check everything is secure check your sparks are in sounds like a slipped belt but eliminate all other possibilities
As super said a vid always helps
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 22nd Apr 2016 at 09:44
finnie
Thanks will try upload a video in the next hour,anyway of checking if belt has slipped
Moonstone gti6
Posted 22nd Apr 2016 at 15:30
finnie
Would the car still start then if the belt has slipped?
Moonstone gti6
Posted 22nd Apr 2016 at 15:32
It will probably start if the belt has slipped a tooth, but there will be bent valves and it will run like a pig. Yes
Posted 22nd Apr 2016 at 15:50
finnie
Can't seem to upload a video
Moonstone gti6
Posted 22nd Apr 2016 at 16:34
Cjwatson27
Not a heat shield is it ?
Posted 22nd Apr 2016 at 16:45
finnie
Should timing belt be really tight?it seems a bit slack
Moonstone gti6
Posted 22nd Apr 2016 at 16:50
mocinim
It shouldnt be slack
Posted 22nd Apr 2016 at 16:53
cully
turn the belt 90degres at the longest point is right
45degrees is too tight
been there done that Wink
Posted 22nd Apr 2016 at 17:23
finnie
Belt is slack between the 2 cams so think it has jumped as it shouldn't be slack there
Moonstone gti6
Posted 22nd Apr 2016 at 20:07
check the plugs
Posted 22nd Apr 2016 at 20:14
rich_w
It is normal for a little bit of slack between the cams, due to they way they sit.
It won't be tight tight anyhow.
It has to be very slack to jump a tooth.
It's worth checking:
- timing
- plugs
- check cam sprocket bolts are tight
Contact Details:
07732 822546
Posted 22nd Apr 2016 at 20:33
finnie
Checked plugs and 3 were slack,tightened up and started and still running like its misfiring and like a rapper rattle from top end of engine.the timing belt I can nearly skip off by hand,shouldn't be able to do that should I???
Moonstone gti6
Posted 23rd Apr 2016 at 15:52
finnie
Tappet rattle
Moonstone gti6
Posted 23rd Apr 2016 at 15:53
mocinim
NO
Posted 23rd Apr 2016 at 16:21
finnie
Maybe tensioner has gave way or something,getting it looked at on Tuesday,might be selling as spares or repairs by the looks of things 😩😩😩
Moonstone gti6
Posted 23rd Apr 2016 at 16:36
mocinim
What colour
Posted 23rd Apr 2016 at 18:03
finnie
Moonstone,v reg.car only done 92000
Moonstone gti6
Posted 24th Apr 2016 at 00:14
Cjwatson27
In that case kill it
Posted 24th Apr 2016 at 00:35
Sounds like the belt has slipped then if it's that loose.
Either the tensioner will have moved or the adjustable cam pulley(s) may have come loose.
Posted 24th Apr 2016 at 10:00
finnie
Timing belt had stripped 6 teeth of it,stuck new belt on it and car runs fine apart from a tapping noise now,gets louder when u Rev the car!could it maybe have caught a valve or would the hydraulic tappers break up?
Moonstone gti6
Posted 30th Apr 2016 at 02:00
p-silva21
6 teeth are too much.. either way, that head will have to came off Unsure
Posted 30th Apr 2016 at 02:10
