displaying posts 26 to 39 of 39
Pages (2): 1 [2]
Author Subject: Bad tapping from engine
finnie
Don't want to spend anymore money and time on it to be honest,might try and sell it or break it unless anyone has cheap engine or a head
Moonstone gti6
Posted 30th Apr 2016 at 02:32
rich_w
They hydraulic lifters don't ever fail to be honest.
You will have some bent valves. 6 teeth is quite a lot in terms of camshaft degrees.
I have a cheap reconditioned cylinder head for sale in the For Sale forum, if you want to get her fixed up.
Contact Details:
07732 822546
Posted 30th Apr 2016 at 08:28
mocinim
Fix her bud if you sell her shell go to scrap most likely the vultures will pull her apart
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 30th Apr 2016 at 09:12
finnie
Don't know if I want to chuck a fair bit more money at the car to be honest,I have spent a Wee bit recently changing all brakes,calipers etc already and the cars aren't worth that much anymore.not sure wat I would get if I sold it tho,thanks rich had a look but undecided as it's an expense
Moonstone gti6
Posted 30th Apr 2016 at 09:37
300 for a head, 100 for pump and belt kit, 15 for bolts, 40 for gasket.
itll be good for another 36k when the belt will be due again.
rule 1 of gti6/rallye ownership:
change the belt.
Posted 30th Apr 2016 at 11:05
tappets can fail, especially at the age they are now, I was a bit sceptical till recently, when i found half a dozen in one head.
however this WILL be a few bent valves
Posted 30th Apr 2016 at 11:07
dendle89
Does it Tap when the engines cold ? - or just starting
Team 6 Cylinders
Posted 30th Apr 2016 at 11:10
finnie
Taps went engine is cold or hot,will do a compression test as I tried a stefoscope on it and tapping is coming from cylinder 2 inlet.
Moonstone gti6
Posted 30th Apr 2016 at 16:11
finnie
Belt got done 21,000 miles ago so should still have had a bit of life in it
Moonstone gti6
Posted 30th Apr 2016 at 16:14
finnie
Post #35
Would I still be able to use car or would it do more damage?
Moonstone gti6
Posted 30th Apr 2016 at 16:17
cully
Post #36
head of the valve will eventually break off and destroy the engine
ATM it is fixable with a head rebuild
if you loose the valve it is a replacement engine complete
Posted 30th Apr 2016 at 17:24
Post #37
mileage is irrelevant if its too old, or the tensioners weren't changed
Posted 30th Apr 2016 at 18:03
finnie
Post #38
Done a compression test and all cylinders are 200 psi,could it still be a bent valve or more a hydraulic rapper?
Moonstone gti6
Posted 3rd May 2016 at 15:47
finnie
Post #39
Tappet
Moonstone gti6
Posted 3rd May 2016 at 15:52
Pages (2): 1 [2]
