displaying posts 51 to 75 of 92
Pages (4): first .. 2 [3] 4
Author Subject: misfire
lee306rallye
Post #51
My relay was cracked an water got in it
http://www.306gti6.com/forum/showthread.php?id=163869
Posted 31st Mar 2016 at 18:38
lee306rallye
Post #52
Change the fuel pump relay mine operated in the normal way as you would expect on prime and so on but if it's got wet inside as did mine after a jet wash then this could be your issue. I'm pretty sure it will behave after.
Posted 31st Mar 2016 at 18:48
Post #53
Has a brand new one chap. Found Aaron's one was indeed cracked and split open but had a brand new one of the shelf at work so changed that some time ago.
Posted 31st Mar 2016 at 19:30
Post #54
mocinim wrote:
Any one got a circuit diagram for this
For what?
Posted 31st Mar 2016 at 19:38
aaron6
Post #55
Is that the multifunction relay behind the relay that we changed?
Posted 31st Mar 2016 at 19:53
Cjwatson27
Post #56
Does it have a cat ? It's not that broken up and restricting back pressure. Really random quess
Posted 31st Mar 2016 at 19:55
lee306rallye
Post #57
Was it changed after the jet wash
Posted 31st Mar 2016 at 20:05
aaron6
Post #58
It's been decatted as the original cat wasn't a fan of the over fueling and decided to implode.
Posted 31st Mar 2016 at 20:08
aaron6
Post #59
The multifunction relay was indeed changed after the wash as it was running perfectly before hand.
Posted 31st Mar 2016 at 20:07
Cjwatson27
Post #60
That rules that out. I hate this I broke my last gti6 because it kept developing a massive flat spot every now and then swapped over loads of parts never sorted it
lee306rallye
Post #61
Are we talking about the same relay the one behind the battery/ecu box
Posted 31st Mar 2016 at 20:12
aaron6
Post #62
We'll get there I hope. I've had this car for 6 years now so have no intentions of giving up on it. I'd probably a buy a perfectly good one to use for parts to salvage mine. LOL
Posted 31st Mar 2016 at 20:13
Post #63
Yes black one commonly called fuel pump relay but gives power for spark etc too so technically multifunction relay.
Was annoyed when that didn't cure it.... had.a nice bulge and crack in with a large gap so thought water probably got in there. Got 2 used and one new at work so threw that on still the same.
Posted 31st Mar 2016 at 20:15
lee306rallye
Post #64
Do you think this is more an electrical problem or a mechanical problem because reading some parts of the thread to me it looks like there's a dirty engine with an inlet with resonator box and a nice clean engine without the inlet resonator box obviously the inlet has been off and painted and a welded bung in the hole. I have no idea what welding a bung in place to do away with the box but could this be the issue or a faulty inlet gasket could cause s**t running. Maybe have a look around there. Or maybe the little vacuum pipe is blocked.
Oh btw not sure if it's actually called a resonator box I just wanted to sound smart like you
Posted 31st Mar 2016 at 20:30
aaron6
Post #65
Yes. It had a bung welded in and was powdercoated. The bung shouldn't make any real difference. Many 6's have done away with the resonator. It's a brand new gasket and as far as I'm aware the little pipe is clear although pete will clarify that. It's all sealed up as it was all sprayed with a brake cleaner or something. If it revved up it was taking it in and burning it but it didn't. Also, the misfire started as soon as it was washed.
Posted 31st Mar 2016 at 20:53
lee306rallye
Post #66
1st time I've saw it been done away with. I'm lost then mate I have no more answers. I'M OUT
Posted 31st Mar 2016 at 21:13
Post #67
Got a red rallye for sale LOL
Posted 31st Mar 2016 at 22:23
aaron6
Post #68
I'll give you £200 and a half eaten bag of quavers.
Posted 31st Mar 2016 at 23:06
mocinim
Post #69
Ill do 201 a full bag of skips and a crunchy
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 31st Mar 2016 at 23:20
Post #70
Here's something to check/think about.
Check the condition of engine wiring loom running to the lambda plug...I have known in the past that this wiring has become damaged/burnt and caused intermittent bad running.
Posted 31st Mar 2016 at 23:29
mocinim
Post #71
armzsc6 wrote:
For what?
Injector n coil pack wiring circuit
Sorry didnt realuse that had sent was on the train
Posted 31st Mar 2016 at 23:40
Post #72
When all this is sorted out, I have a genuine CAT should you need one?
Just got to dig it out first.
Posted 1st Apr 2016 at 00:39
aaron6
Post #73
I have a spare of unknown condition so I may take you up on that mate. Smile
Posted 1st Apr 2016 at 07:10
Post #74
It's my original, removed in 2005 and dry stored ever since.
Problem is it's in my mates garage and getting hold of him is a nightmare! Yes
Posted 1st Apr 2016 at 07:26
aaron6
Post #75
LOL
How much you want for it anyways matey?
Posted 1st Apr 2016 at 10:07
