displaying posts 76 to 92 of 92
Pages (4): first .. 2 3 [4]
Author Subject: misfire
Post #76
£80 mate and I'll deliver it to you.
Just got to get hold of it first...
Posted 1st Apr 2016 at 15:33
aaron6
Post #77
Okay fella. Ta very much. I'll let you know on it as do have the unknown spare and to be fair, I drove it last night and it was absolutely flying with the decat and de-resonated inlet manifold, newer injectors and coils and and a huge array of sensors and an ecu. LOL
Is there a way to lock a soft unlocked to my car?
Posted 2nd Apr 2016 at 06:45
Post #78
If it's soft unlocked it should lock to your car once you switch it off...then to unlock it again you will need to cut power to it after you've gone two clicks on the ignition.
Posted 2nd Apr 2016 at 09:37
pug_306
Post #79
I dont think it will lock to his car. It will just lock and wont start the car again. You need to leave transponder unplugged
1992 205 GTi6
205 Turbo 340bhp
Posted 2nd Apr 2016 at 10:18
aaron6
Post #80
Ah that's what I'd heard Ryan. I might invest in an unlocked one if I see one cheap enough.
Posted 2nd Apr 2016 at 10:33
Post #81
Any progress on this Aaron? Unsure
Posted 6th Apr 2016 at 15:32
aaron6
Post #82
Yes mate. Just running to check it stays okay. We used the soft unlocked ecu and another set of coils and the problem was sorted. Put the old ecu in lastnight and it seems perfect. In fact, better than perfect. It f**king flies for a standard one now. And the the noise we always thought was a lazy lifter when cold appears to have gone too.
Posted 7th Apr 2016 at 21:51
Post #83
Interesting.
I'm glad you've made some progress, most likely your original ECU suffered from water after the jetwashing. Pretty unlucky for that to happen though.
Posted 11th Apr 2016 at 13:40
aaron6
Post #84
That's the thing, we refitted the old ecu and it's fine. Very odd.
Posted 11th Apr 2016 at 15:18
Post #85
It may have had a drop of water in it and by removing the ECU it has been dislodged and now the unit functions as normal.
Glad it appears to be resolved anyhow. Thumbs up
Posted 11th Apr 2016 at 16:46
aaron6
Post #86
Maybe. Who knows. LOL
Seems alright now and as I say, it flies with all new or lower mileage bits and the few other little mods we did along the way. Smile
Posted 11th Apr 2016 at 16:52
Post #87
Changing the ecu never cured anything so I don't think it was the problem. The first time it ever ran nicely for a couple of hours was after I cleaned up all the earth's and added an extra one to the head. It then ran fine until Aaron collected it and it then misfired again on and off causing backfires etc.
I think it was the fact the loom and the arts got wet that started the initial problems with the earth's on the gearbox / wing then there was another sensor and a coil that weren't happy after it had misfired a lot and not burned a load of fuel. (Also destroyed the cat)
The ecu was bone dry however there was an oily residue on the pins but that didn't seem to be affecting anything and may have been there for years.
It would then run fine for a while then a dodgy coil would mess about. God knows though tbh we changed just about everything and cleaned up everything so could have been anything really.
Posted 12th Apr 2016 at 20:33
aaron6
Post #88
Either way the f**ker is working now.
Posted 12th Apr 2016 at 21:41
Post #89
As you say Pete, it was probably a whole host of things which snowballed from a relatively simple fault to begin with.
Glad it's fixed though, was a head scratcher...
Posted 15th Apr 2016 at 07:01
aaron6
Post #90
Does look good now though. Gotta be one of the better looking 160+k engine bays now.
Posted 15th Apr 2016 at 15:17
-er-
Post #91
What a ridiculous problem. I think my problem is the ECU and I had done a jet wash before I had this problem.
I removed all the sensors and cleaned all the grounding points. All the fuses and all the relays were changed or measured with a multimeter, but the multifunctional relay still does not work as it should.
It all started like this
https://youtube.com/shorts/cqq7CLdzni8
https://youtube.com/shorts/ovz7hmaeBLY
https://youtube.com/shorts/KaQtlCmI52Y
https://youtube.com/shorts/PgC2zq-WKX4
https://youtube.com/shorts/bHYEy4CvotI
https://youtube.com/shorts/i9skIsI4sFs
https://youtube.com/shorts/cAS0V_2Bfk4
https://youtube.com/shorts/AEuz6d66TGw
https://youtube.com/shorts/JSarE_em4ac
https://youtube.com/shorts/YZDMWjiG-q4
https://youtube.com/shorts/gbgd8yQ2wm0
https://youtube.com/shorts/prHFKbfgoec
https://youtube.com/shorts/CMW5TcBGf5I
I will continue to try and make videos.
My Channel EREL
Peugeot 306 GTi-6 N5 / PH2 / Diablo Red / Mustang Red Cloth (Sold Sad )
Peugeot 306 GTi-6 N5 / PH3 / Diablo Red / Alcantara Suede
Peugeot 306 GTi-6 N5 / PH2 / Bianca (Sold Sad )
Posted 29th Dec 2024 at 08:11
jimmyhackers
Post #92
high octane fuel and the gti6 do not mix.....
octane is not the power it has
it is its resistance to pre-detonation!!!!!
ergo high octane fuels in the gti6 can resist combustion leading to misfires.
Posted 29th Dec 2024 at 16:56
