Author Subject: Correct spark plugs for low boost
ben01328
Hi guys can someone confirm these are the correct spark plugs for my rotrex low boost.
http://m.ebay.co.uk/itm/4x-NGK-2668-Spark-Plug-Set-Genuine-Engine-Ignition-Sparkplug-Iridium-BKR8EIX-/182005845669?nav=SEARCH
Cheers.
Team Boosted Hyper
Team 330mm Cool
Posted 25th Feb 2016 at 21:36
6waysforward
NGK BKR7EIX's [road use] or the BKR8EIX's [road & track use]
I had BKR7EIX in my low boost if that helps.
Think i have a set knocking about that only covered 10 miles. Thought it was the plugs causing an issue so bought new ones. Turned out to be bottom end Sad
Yours for £15 delivered.
Posted 25th Feb 2016 at 21:53
ben01328
Would the road use ones suffer from the occasional bit of track use? and would you notice any difference from the track use ones one the road?
Team Boosted Hyper
Team 330mm Cool
6waysforward
I thrashed the s**t out of my low boost (hence it gong wrong) and the plugs were fine but others on here may have used both and experienced the difference Dunno
Infact read this. It will explain all about the plug temps and insulation causing problems
Clicky
Posted 25th Feb 2016 at 22:01
ben01328
Okay cheers mate, I'll see if anyone else has some input if not I'll just get the road use ones.
Team Boosted Hyper
Team 330mm Cool
Posted 25th Feb 2016 at 22:04
Got the 7's in my road going LBSC 6 Thumbs up
Posted 26th Feb 2016 at 10:11
I ran 7's in my throttle bodied engine.
not the extortionate iridium ones though.
Posted 26th Feb 2016 at 11:47
I wouldn't think you'd have much trouble keeping 8's clean on a boosted engine on the road to be honest.
Posted 26th Feb 2016 at 12:31
ben01328
Well it's always used to its potential when I drive so there is no risk of it getting clogged full of s**t that's for sure.
Team Boosted Hyper
Team 330mm Cool
Posted 26th Feb 2016 at 13:05
I ran 8's on my slightly tweaked low boost for 2 years with no problems clean enough on the electrode etc. Swapped to 7's last year though.
Posted 26th Feb 2016 at 16:30
7's are what should be used for low boost. Yes
Posted 26th Feb 2016 at 23:47
