displaying posts 101 to 109 of 109
Pages (5): first .. 3 4 [5]
Author Subject: 306 MAXI BUILD
Post #101
they ran more caster, by a fair bit, so the wheel is moved forwards a fair bit.
Posted 3rd Nov 2016 at 22:58
Ryanennion83
Post #102
Cut all the flange right back and then some right up to the inner wing.
It is a tarmac rally car so need the clearance
Ryanennion83 has attached the following image:
Posted 4th Nov 2016 at 09:37
Ryanennion83
Post #103
Strut top has been moved out as well and double skinned and cage comes into it.
Also had to move part of the inner at the back as well.
Posted 4th Nov 2016 at 09:39
Post #104
some top work there Thumbs up
Posted 4th Nov 2016 at 13:22
Eddleston
Post #105
That's some nice work there!
Posted 22nd Nov 2016 at 13:01
RallyeRed
Post #106
How's this coming along Ryan?
Any more progress for us to drool over?
Iain
Posted 5th Dec 2016 at 16:59
jord294
Post #107
Ryan can you contact me please about the axle you had off me
Posted 28th May 2017 at 07:32
jonbb
Post #108
Hi, I'm sorry for not knowing English and having to go with the translator, I'm jon
The thing is that I have a project similar to yours and I have many problems to do it and I'm lost.
The engine was an xsi and now I'm getting the s16 167cv 6 speed. The rfs.
The thing is that I have to modify suspension shorter because if not the car was very high because of the fins so tall that it has and there is to cover the gap. The problem is that it goes down well but the stick or transmission remain in "v". And what I want is to raise the engine about 2 cm but I thought spinning would also raise the transmission. If you could give me a cable, I would appreciate it
I congratulate you first on the project and a pleasure to meet you.
I am from pays basque in spain.
I have seen or it seems to me in a photo that you have that your transmission of the box comes more arriva or it seems to me.
Apart I want to get cups and put longer blades and longer mangue as some Ford. we are in contact. regards
Posted 12th Aug 2017 at 00:38
Post #109
Top job Ryan ....looking great m8 ...keep the updates & pics coming Thumbs up
Posted 12th Aug 2017 at 09:52
