displaying posts 51 to 75 of 109
Pages (5): first .. 2 [3] 4 .. last
Author Subject: 306 MAXI BUILD
pugheaven
Post #51
How wide did you go with the spacers? Any camber machined in?
Are the beam mounts shallower/shorter then standard?
Posted 4th Jul 2016 at 20:57
Twangy
Post #52
Ryanennion83 wrote:
Yeah flying now.
The beam is ready to collect next week from Andy Williams. Had Bridgecraft do the wider rear arm
Conversion solid mounts etc....
The front wider suspension has turned up at DIMMA.
Got to go to RED Custom Cages next week with the seats to position them where I want them!
Full steam ahead!
did jolly do cage for you from RED then
wayne mcardle
Posted 4th Jul 2016 at 21:46
Ryanennion83
Post #53
+40 on the spacers with a bit of camber machined in.
Uprated thicker torsion bars
Solid mounts
Posted 4th Jul 2016 at 22:35
RallyeRed
Post #54
Looking good Ryan.
Keep the pics coming..
Posted 5th Jul 2016 at 21:21
RallyeP6
Post #55
Lovely shiny rear beam, looks great.
Posted 6th Jul 2016 at 00:11
Post #56
Ryanennion83 wrote:
Been a while!
Wow surprising how much of the 1/4 panel you can do away with if you want to.
What do the kits come with in way of a wheel arch liner? I'd be wanting to do everything possible to stop any of the cut metal getting rusty. Obviously paint and a tonne of underseal etc too but do they come with liners?
Posted 6th Jul 2016 at 07:45
Chr1sch
Post #57
Damn this is going to be something else!
Posted 6th Jul 2016 at 11:14
RallyeRed
Post #58
Pete I've done similar on my Scoob with the WRC kevlar panels I'm fitting.
I've cut quite a lot away, but in hindsight this has more to do with following the original build format in the Prodrive era than by design as such. If I did it now I'd may be retain more of the original panel - actually in my case a lot of it was rusty now that I think about it - which was the catalyst for doing it in the first place.
That said, building in fresh metal to extend the arches adds a lot of strength back into the area. The turret will benefit from another strengthener as will the sills near the back when the jacking points go in.
This is a mock up of the steel when I was cutting it to size, which shows how much was cut out -
And a pic before the weldathon began
I think if you could fold and lip the original arches you would be fine with a twintex arch liner bonded in. If you have to cut a lot out for a tub inside the arch then fresh metal to keep things strong would be the way to go.
Iain
Posted 6th Jul 2016 at 18:04
Post #59
Awesome work! Thumbs up
Posted 6th Jul 2016 at 19:00
Ryanennion83
Post #60
Decent!
Yeah got a carbon composite inner arches
I'll post pics as I go to show you how I'm doing it.
Going Tomos to have the seat frames welded in to suit the seat and me.
Will post more pics Tomos!
Posted 6th Jul 2016 at 19:37
RallyeRed
Post #61
Need to chat with you Ryan about painting the Impreza when I've finished it.. I'm only down the road from you Smile
Might have to try and swap you for the maxi Wink
Posted 6th Jul 2016 at 21:08
Ryanennion83
Post #62
Cage nearly complete.
Just got outer tunnel to take out to get seat rails in.
It was in good company as there was a 106 Maxi works car in having some work done!
Nice!
Ryanennion83 has attached the following image:
Posted 7th Jul 2016 at 09:13
Ryanennion83
Post #63
Cage
Posted 7th Jul 2016 at 09:14
Ryanennion83
Post #64
Cage
Ryanennion83
Post #65
Cage
Posted 7th Jul 2016 at 09:15
Ryanennion83
Post #66
Cage
Posted 7th Jul 2016 at 09:16
Ryanennion83
Post #67
Cage
Posted 7th Jul 2016 at 09:18
Ryanennion83
Post #68
Cage
Posted 7th Jul 2016 at 09:19
Ryanennion83
Post #69
Cage
Ryanennion83
Post #70
Cage
Ryanennion83
Post #71
106 MAXI
Posted 7th Jul 2016 at 09:20
Post #72
Nice work! Thumbs up
Posted 7th Jul 2016 at 10:55
RallyeRed
Post #73
Sweet!
Posted 7th Jul 2016 at 15:57
Ryanennion83
Post #74
So I'm after bits still brakes, suspension I.e shocks got the rest done. Basically any parts anyone has that they think would work pm me! Ta!
Posted 10th Jul 2016 at 21:22
RallyeRed
Post #75
Ryan I think you need to choose front shocks with care to get ride height independent of damping adjustment. I think you need something like 60-70mm drop if I've read correctly. KW V2's could be a good way to go - be wary of the cheaper stuff!
Posted 10th Jul 2016 at 21:46
