just one thing id do with those if n9t already done is a good radius on the bolt hole as the standard bolts hve a larger one than stock capscrews
I’m not sure what Dave’s upto but he’s modifying both my Calipers slightly...
Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #1576
quote: [quote="welshpug!"]Nice work Dave just one thing id do with those if n9t already done is a good radius on the bolt hole as the standard bolts hve a larger one than stock capscrews I’m not sure what Dave’s upto but he’s modifying both my Calipers slightly... |
Posted 12th Nov 2017 at 19:39
Post #1577
Something different ...A few of you may be aware .... Ive been helping Will Declaudio this year at Castle Combe Saloon racing with his 106 / 1700T Sandy Brown Race Engine Car .... Anyway this year Will came 1st in class ...PLUS came 3rd overall against every other car + lots with 550bhp / turbo charged cars ... ( Most important we won best turned out Team ) Picture at Combe Awards of Will / and his Wife Amelia .... PS ...I’ve learned SO SO much doing this Day666 has attached the following image: |
Posted 13th Nov 2017 at 09:29
Post #1578
Will De Claudio’s Last Race at Coombe against 550+ bhp Cars in two higher classes ...https://m.youtube.com/watch?v=1RQya8lzxF8&feature=youtu.be |
Posted 14th Nov 2017 at 12:05
blandy
Post #1579
was a good day. still impressive how the little 106 gets off the line every time |
Posted 14th Nov 2017 at 12:07
demondriverdan
Post #1580
Congrats on getting engaged as well Damo, you'll have less money to spend on the car now ________________________________________ Rallye Race Car |
Posted 14th Nov 2017 at 12:43
Post #1581
quote: [quote="blandy"]was a good day. still impressive how the little 106 gets off the line every time Totally agree Michael ....was a great day too |
Posted 14th Nov 2017 at 12:53
Post #1582
quote: [quote="demondriverdan"]Congrats on getting engaged as well Damo, you'll have less money to spend on the car now Thank you Dan m8.....to be truthful all the really Big Money’s been spent now ...unless I find some way of buy a Tony Palfrey 6 speed full Sequencial box Sometimes you have to give a little to get a little |
Posted 14th Nov 2017 at 12:56
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,268 Status: Offline |
Post #1583
Stunning thread ... I have a spare part in the garage which is a different kind of gear stick mount design which might be useful for a track orientated car with so many upgrades. It is a very direct engagement for the gear selection. I will try dig it out over the weekend. |
Posted 14th Nov 2017 at 21:00
blandy
Post #1584
Any pics of the doors all fitted up? Ref the windows j see you had some made are they different to a normal Lexan window? |
Posted 14th Nov 2017 at 21:45
Post #1585
quote: [quote="iplay"]Stunning thread ... I have a spare part in the garage which is a different kind of gear stick mount design which might be useful for a track orientated car with so many upgrades. It is a very direct engagement for the gear selection. I will try dig it out over the weekend. Brilliant Neil Thank you |
Posted 15th Nov 2017 at 03:50
Post #1586
quote: [quote="blandy"]Any pics of the doors all fitted up? Ref the windows j see you had some made are they different to a normal Lexan window? Yes page 55 ....post 1358-1360 Michael Only difference is they are hard-shell Marguard = scratch resistant polycarb m8 ...1/4 as much again sadly plus fitted scoops to get more air in when the windows are open .......plus putting more bolts to pull them in tight / fix them flat all round with no lifting anywhere seemed to strengthen the door surround ?.... OTT I know plus added a little weight but remember they are Kevlar/ Carbon composite Doors so anything that strengthens them slightly helps ... Tony Palfrey Carbon fitted door panels made a difference...weird but 100% truth ...the Doors didn’t flex hardly before Fitting these bits but helped 25% I recon |
Posted 15th Nov 2017 at 04:43
blandy
Post #1587
Cool thanks yeah seen the door pictures but not fitted to the car lol just wanted to see how they fit compared to standard i.e is it glaringly obvious there different. |
Posted 15th Nov 2017 at 11:43
Post #1588
quote: [quote="blandy"]Cool thanks yeah seen the door pictures but not fitted to the car lol just wanted to see how they fit compared to standard i.e is it glaringly obvious there different. I’ve fitted them and with them being primed Wht they stand out ...but the fit is great 90% |
Posted 15th Nov 2017 at 11:54
blandy
Post #1589
quote: [quote="Day666"]PS ..anybody know or Guess better than me what 25mmTBs will need my dummy shock set to get similar ride height to my current 21mm TBs which came in at 313mm give or take 1mm per side ? That measurement is centre to centre ..I take it 30mm approx drop from standard ride height ? How did you get on with your measurements? I want/need to raise mine up as is a bit low at present |
Posted 16th Nov 2017 at 19:18
Post #1590
quote: [quote="blandy"] quote: [quote="Day666"]PS ..anybody know or Guess better than me what 25mmTBs will need my dummy shock set to get similar ride height to my current 21mm TBs which came in at 313mm give or take 1mm per side ? That measurement is centre to centre ..I take it 30mm approx drop from standard ride height ? How did you get on with your measurements? I want/need to raise mine up as is a bit low at present I set my Dummy Shock on the rear 295mm in the end ....which was spot on with 25mm TB ....I dropped my front also 20mm ....I’m really happy with the height 35mm front gap to bumpstop / 35mm rear gap between rear arm to bump stop |
Posted 16th Nov 2017 at 22:30
Post #1591
Small but important updates to get my car back working again after going 50mm plus wider track ....Satchell via Tony Palfrey bells and Adaptors plus solid extended driveshafts .... Bailcast (Neoprene) CV boots with crush type fixings and clamp tool 3 litres of Gearbox oil ...I don’t use two ( why in earlier post ) Day666 has attached the following image: |
Posted 7th Dec 2017 at 14:12
Flatoutfarr
Junior User Location: Corby Registered: 03 Aug 2016 Posts: 88 Status: Offline |
Post #1592
Can I just congratulate you and DD Dan for 2 of the most educational threads I have read on this forum? As a newbie to 306 GTI-6's, and trying to race one, the pictures and advice from various people have been so useful. They should be saved as part of FAQ's once completed so the rest of us can refer to them in times of need ! Well done to both of you. I now need to rob a bank to get some of these fancy bits !! ________________________________________ Adventure before Dementia !! |
Posted 7th Dec 2017 at 16:52
Post #1593
Thank you Chris but I take my ideas ...which a lot have been done well before me from lots of others on here also ...and some that are no longer on here m8.....I do try to think outside the box but most of it has been done somewhere |
Posted 7th Dec 2017 at 22:08
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
Post #1594
Driveshafts look good Damo. What are you doing for the tripod ball joints? |
Posted 8th Dec 2017 at 07:36
Post #1595
quote: [quote="RallyeRed"]Driveshafts look good Damo. What are you doing for the tripod ball joints? Thank you Iain Do you mean bottom ball joint ? I’m running 406 hubs if so ... Day666 has attached the following image: |
Posted 8th Dec 2017 at 10:56
RallyeRed
Post #1596
No mate, I mean't the inner cv joint on the driveshafts. It's called a tripod joint/bearing I believe. And i also think they're NLA which is why I was asking. Cheers |
Posted 8th Dec 2017 at 18:11
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,839 Status: Offline |
Post #1597
they've never been available separately, I'd imagine they'll be going in the shafts he already has.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 8th Dec 2017 at 19:22
Post #1598
quote: [quote="welshpug!"]they've never been available separately, I'd imagine they'll be going in the shafts he already has. As Mei said Iain they will be going into my original Inner CV joint m8 |
Posted 8th Dec 2017 at 21:19
RallyeRed
Post #1599
cheers both |
Posted 8th Dec 2017 at 21:33
Post #1600
Guess what I’m upto as well as helping Will take his engine out to give to Sandy Brown for refresh Day666 has attached the following image: |
Posted 9th Dec 2017 at 13:48
