Looks brushed tbh
The good thing about brushing paint is it goes on bloody thick & wont wear so easy
I'll post some pics of mine when I've finished it ....can't fault this spray apart from the cost of each tin .
Everything sorted on yours now Adam ?
| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #76
adam b wrote: I brushed mine. But it was already sort of painted. Looks brushed tbh The good thing about brushing paint is it goes on bloody thick & wont wear so easy I'll post some pics of mine when I've finished it ....can't fault this spray apart from the cost of each tin . Everything sorted on yours now Adam ? |
Post #77
It's never sorted completely. Decided not to work this morning, no idea why. Piece of French s**t. ________________________________________ Nothing to see here |
Post #78
Right small update ....collected my new remanurfactured clutch cable .All ready for my Helix Clutch & Pressure plate .. Speedycables in Swansea took a new 6 clutch cable I bought from ECP for £24 & made both metal ends & took the automatic adjustment out & used most of the outside stuff .... Charged me £59 inc vat & delivery ... Hopefully that sorts out the weak spot on the cable ? Now also have metal ends for the throttle cable to the pedal also similar to the clutch end . Day666 has attached the following image: |
Post #79
Close up now has a old style ajuster ...all metal including the normal half oval which is always white plastic now metal Day666 has attached the following image: |
Post #80
All metal ends Day666 has attached the following image: |
Post #81
That's a bargain fair play.The white clips are the weekness in these bas**rds |
Post #82
Nice one, handy to know about the cable too as i've snapped a few myself ![]() ________________________________________ Goldie the track car. |
Post #83
roland rat wrote: That's a bargain fair play. The white clips are the weekness in these bas**rds Never personally had one go Ash / Stephen I'm trying to avoid it happening though & been told these Helix pressure plate kill them in 6months ? I thought for a bespoke item that was a fair price myself .... If anyone wants one you will need a old cable / new one really I feel for some of the bits as they don't stock them & I've made sure they kept a file on the size just incase I ever need another ..Took 2wks though ! |
Post #84
still got plastic outer cable ends should be ok though.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #85
welshpug! wrote: still got plastic outer cable ends should be ok though.I was always told it's the plastic Clutch pedal end that goes Mei ?....it's got to be 100% better than standard ? And the idea was I can now ajust the pedal to my liking . |
fatlapit
Post #86
It will be fine i always have a spare clutch cable but never broke one________________________________________ |
Post #87
fatlapit wrote: It will be fine i always have a spare clutch cable but never broke one Cheers Chris |
Post #88
Removed as much spare wiring as I could in side my car tonight .....these looms are crazy ...rear electric door loom in a 3 door ...waste !So much generic loom ... All the spare copper wire filled a large TESCO plastic 5p bag ... We weighed it & came to just over 5kgs ...mental ...I was so surprised PS don't forget I've still got all my door loom inc electric Windows ...for now & electric mirror & central locking loom at mo ...5kgs plus saving 7kgs on my flywheel all helps to make up for the cage weight |
demondriverdan
Post #89
I've created a brand new wiring loom for the race car. Think the total thing weighs less than the fusebox of the old loom!________________________________________ Rallye Race Car |
Post #90
demondriverdan wrote: I've created a brand new wiring loom for the race car. Think the total thing weighs less than the fusebox of the old loom! Fair play Dan Did you just use the ends & connections with new cable or just cut out the unwanted as I've done ? |
demondriverdan
Post #91
Cut off the ends I needed (lights and wipers only really) and soldered them on to new wires. No point cutting out as there was so much I didn't need it was far easier to create a new loom. I'm not running the standard dash etc. any more.Took a bloody long time and I'm not happy with the wiring inside the car so will need to spend time sorting that out, will have to wait though. ________________________________________ Rallye Race Car |
Post #92
Well done Dan ...don't forget to post some pics as Pics answer more questions than words m8 |
demondriverdan
Post #93
Not posting any pics of the wiring, it's a mess and I really don't like it! One day I'll sort it out and then might post some but running out of patience with the car already so maybe not!________________________________________ Rallye Race Car |
Post #94
After sorting out all my Electrical probs.....I had to fit a new battery Isolator as the old second hand Ebay 150amp so say £7 one fell apart inside ...Spent a few bucks on a competition Lorry one 250amp full time & 2500amp cranking ....it weighs a bit & feels quality & is all metal inside & out apart from the black isolation caseing outside ..Totally overkill x3 (I KNOW) but the car 150% does start much easier than with the other & better to be 110% with it failing again Day666 has attached the following image: |
Post #95
Well I've finally gone & done it ...said I wouldn't but a wire was broke in my drivers side door loom right up by the end so new short loom was needed ...so I removed everything electric in both doors & fitted manual winders tonight that Miles supplied from his old race car ...2kgs of just door looms & Manual winders are half the weight of Electric ... I've removed 9kgs of electric windows & interior loom & Both door looms & 13 fuses now not required Picture below is just both door looms crazy Day666 has attached the following image: |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
Post #96
Ha and im having to replace mine as it broke over the weekendsod Keep fit windows! |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Post #97
Haha no way! Good man, was the keep fit setup hard to fit? |
Post #98
cully wrote: Ha and im having to replace mine as it broke over the weekend sod Keep fit windows! Can't believe how easy it is to convert to Manual Windows 5 Bolts ! These looms in the doors looks Rubbish |
Post #99
Chr1sch wrote: Haha no way! Good man, was the keep fit setup hard to fit? I would of kept the Electrics Windows if I had a choice but the main white thick power wire was snapped right by resin block & couldn't be mended ... Really easy to fit manual Windows Chris- 30min job each side Only problem is I have to open the door slightly to open the window because window winder handle hits door gusset half way round ....not a massive issue if I'm honest |
Post #100
anything can be fixed!!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
