| Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #3226
Post #3227
I can now go 225 easily |
Joep
Senior User Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 501 Status: Offline |
Post #3228
Wow! That is going to look amazing!________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
Post #3229
Joep wrote: Wow! That is going to look amazing! Massive thank you |
Post #3230
What is being made is the connection on the rod to the Red Actuator on this blurry pic but a bit more design |
Post #3231
Post #3232
Hes 3d printing me a trial piece to try The original final piece will be Billet Metal and Nickel plated |
Post #3233
It will fit onto the spherical bearing on The far right with a 8mm bolt ![]() |
Post #3234
Made to try and modify anything before Billet steel one gets made Didnt put 8mm thread yet as it may need reverse thread on this end ? |
Post #3235
Silver temp before going Black when made in (Billet Steel)This is just a quick mock up the steel one has Rounded corners instead of square A little bit of Probolt TART Titanium in blue ![]() |
Post #3236
Bit of OTT |
Post #3237
He it is in Silver and will be made in (Billet Steel) and be coloured BLACK |
Post #3238
Mock up in Black I personally think -Much better look ![]() |
Post #3239
Mock up |
Post #3240
New Full (DW mk2) Carbon dash 1.14kg with mock up paddle shift Sequencial now |
Post #3241
Just Paddles levers to find for the steering wheel Ill have a look at Autosport in January |
Post #3242
Already a newer version/ stronger with thicker side walls and flat internals with rounded corners in BLUE but will be BLACK finished Making it in 3d print you find out all the little things ![]() |
Post #3243
Post #3244
Thicker hollow side internal walls |
Post #3245
some top quality 6mm x 6mm narrow (spherical bearing joints) for the steel rods of my Sequencial gear change paddle shift actuator They are Left Hand thread so combined with the normal Right Hand thread on the other end they ajust to take slack up or loosen ![]() |
Post #3246
3years ago today the car was out in anger at Castle Combe Loads changed since then |
Post #3247
blandy
Post #3248
Was defiantly used in anger 😀 |
Post #3249
blandy wrote: Was defiantly used in anger 😀 Yes ….Its made to use hard |
Post #3250
You can see 6mm wide i needed on left with L/H thread = backwards thread to standard And common 9mm wide on right of the picture |
