Made the 50mm hole that I cut out with a hole saw bigger by 1.5mm with Perma-grit end in my Dremel drill ...
Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #3001
Made the 50mm hole that I cut out with a hole saw bigger by 1.5mm with Perma-grit end in my Dremel drill ... |
Posted 6th Dec 2020 at 16:21
Post #3002
Trial fitted the trumpets inside ...now just got to get the new backplate made |
Posted 6th Dec 2020 at 16:23
jeffers
Forum Admin Location: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Post #3003
Day666 wrote: jeffers wrote: Day666 wrote: jeffers wrote: gnrlee wrote: Want some Free Forum Stickers for the Beast sir? I think you've Earned them! Cracking Job! Woah woah woah, what u mean FREE???? There’s bills to pay David!!! Cough cough ....Excuse me boss man !!!! I remember a certain me looking after you rather well in the Jenvey / Airbox department Erm it was a joke mate! I know but you’ve got to make the most of you posting Fair one! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Posted 6th Dec 2020 at 22:26
Post #3004
Got the final new alloy backplate yesterday |
Posted 12th Dec 2020 at 13:37
Post #3005
Tried the new Trumpets |
Posted 12th Dec 2020 at 13:38
Post #3006
Posted 12th Dec 2020 at 13:40
Post #3007
Posted 12th Dec 2020 at 13:41
Post #3008
I can start measuring to see how much space I have for a radiator |
Posted 12th Dec 2020 at 13:44
Post #3009
Temp fixing ..Got some 4mm Carbon Fibre sheet to cut and fixed some pieces under the bracket plates then screw them from the outside through the Carbon and Carbon/ Kevlar that way nothing inside the Maxi Airbox to come loose or break off and get sucked into the engine .... Finally getting somewhere Now to modify my bonnet for a mould with a bulge for the new design |
Posted 17th Dec 2020 at 05:22
Post #3010
Sad as it might read -it’s a very exciting day today ...I’m hoping the bumper will be ready by this Friday -Monday to collect? ....The original Maxi (plus 50) bumper off Tony Palfry / Maxi Motorsport was cut about and modded loads ...bits of alloy bent and bonded and bits glued on in places it weighed 19kgs but was only made for me to test on the track with ...it would then be moulded to what I wanted and needed with the help of David Warren / General Lee on here and his Carbon Dimma splitter which I bonded on and blended in ...that was originally made for Oliver Church who had the steel winged stunning Blue Dimma which sadly was sold ... Now hopefully I will have a super strong / stiff one piece super lightweight bumper that’s made of Carbon / Kevlar that will hopefully take a knock or two Fingers crossed |
Posted 17th Dec 2020 at 05:29
Post #3011
Posted 15th Dec 2020 at 17:55
Post #3012
A little heated needed to help cure in this cold weather |
Posted 17th Dec 2020 at 05:31
fatlapit
Post #3013
one day you might use the car________________________________________ |
Posted 16th Dec 2020 at 08:34
Post #3014
fatlapit wrote: one day you might use the car One day Chris ...one day |
Posted 16th Dec 2020 at 22:55
Post #3015
fatlapit wrote: one day you might use the car where have you been ? Ok you sold the car but you totally disappeared? |
Posted 16th Dec 2020 at 22:57
Post #3016
Well it’s out of the mould and he’s telling me it’s super lightweight and so rigid / stiff I won’t need ties bars to the splitter ...even better Still a fair bit to do bond the corner air ducts and support internet fixings and cut the grill out |
Posted 17th Dec 2020 at 13:44
Post #3017
It’s ready to collect |
Posted 23rd Dec 2020 at 15:01
Post #3018
Posted 23rd Dec 2020 at 15:02
Post #3019
Posted 23rd Dec 2020 at 15:03
Post #3020
Weighed it today3.46kgs with no paint or Fixings 4.19 kg with everything apart from paint I’m really happy with that Instead of 19kgs for original test master one That’s pair or Aerocatches That’s pair of alloy USA catches A pair of support tie bars for the splitter A pair of inside bumper alloy support brackets and 12 bolts... |
Posted 26th Dec 2020 at 18:24
blandy
Post #3021
Fantastic as always |
Posted 27th Dec 2020 at 17:47
Post #3022
blandy wrote: Fantastic as always Thank you Mike How’s things coming along your end ? |
Posted 28th Dec 2020 at 16:43
Post #3023
It amazes me how things have changed in 4years |
Posted 28th Dec 2020 at 16:46
blandy
Post #3024
Day666 wrote: blandy wrote: Fantastic as always Thank you Mike How’s things coming along your end ? Nothing at all progress wise in mine if afraid. I’m waiting for brakes as satchell are making me some new bells/adaptors to fit the 406 hubs which fingers crossed should be early jan to be done. I need to measure the springs as need helper springs on the new coilovers, ill likely drop engine back in and then get suspension set up and do a quick test day in order to test out gear linkage and suspension changes as was hoping to fit some bigger cams in before race season that are on order but see how time permits as fancy doing some tricolore rounds this year but first race is end of March and at silverstone which I’d like to do, but also just moved house so tied up with diy as well |
Posted 28th Dec 2020 at 17:20
Post #3025
blandy wrote: Day666 wrote: blandy wrote: Fantastic as always Thank you Mike How’s things coming along your end ? Nothing at all progress wise in mine if afraid. I’m waiting for brakes as satchell are making me some new bells/adaptors to fit the 406 hubs which fingers crossed should be early jan to be done. I need to measure the springs as need helper springs on the new coilovers, ill likely drop engine back in and then get suspension set up and do a quick test day in order to test out gear linkage and suspension changes as was hoping to fit some bigger cams in before race season that are on order but see how time permits as fancy doing some tricolore rounds this year but first race is end of March and at silverstone which I’d like to do, but also just moved house so tied up with diy as well Totally understand Mike ... Been there git that tshirt many years ago x |
Posted 8th Jan 2021 at 09:15
