displaying posts 2726 to 2750 of 3423
Pages (137): first .. 109 [110] 111 .. last
Post #2726
If you look by the side of tha black Alloy Corbeau sticker you can see a small gap still
Posted 27th Jun 2020 at 17:03
Post #2727
Large gap still below seat and Sequential gear lever to the right Thumbs up
Posted 27th Jun 2020 at 17:05
pete_rallye
Post #2728
Day666 wrote:
A few updates
Sump spacer for my PACE dry sump to move the crank away from
The PACE dry sump and limit oil Froth and soak and drag Etc ...so say a mod it needs ???
Never heard of that before! I've read all about oil scrapers and stuff on engines but never tried to fit one. A lot of books say that using the dry sump pump to pull a vacuum will eliminate a lot of froth and drag as if there is a vacuum the oil can't suspend itself if the air. I managed to run a small one but it was surprisingly difficult to seal the engine well enough to get a decent vacuum.
The sump has plates in it too which should 'hide' the oil from the effects of the crank. Someone somewhere must've discovered they don't do a good enough job.
Lap of the 'ring
Posted 27th Jun 2020 at 18:37
Post #2729
Pete
Me neither LOL
...guess who that someone is Whistle
I’ve been told I’m going semi sealed system ????
Also been Proven on dunno test bench so say and now is the done thing ...two peoples running it at mo both people you know of well one made his complete dry sump and has tha extra heigh built in Thumbs up
Posted 27th Jun 2020 at 19:58
Post #2730
Small update ...
Been thinking for a while about how I’m going make and design a input support column that’s strong and works but lightweight as well
Here’s my imagination Whistle
Posted 28th Jun 2020 at 19:21
Post #2731
Dash not fitted back in yet but I’m sure you get the ideal ?
Posted 28th Jun 2020 at 19:23
Post #2732
Posted 28th Jun 2020 at 19:24
Post #2733
Small little update
My Cardboard Aided Design has now been turned into a Proper C.A.D file and is going to be cut out of 2mm steel plate next Tuesday and then Both sides bent 90 Degrees
Posted 30th Jun 2020 at 10:40
Post #2734
Big update for me as I can now start wiring my car and 16channel Cartek panel
Full Carbon / Autoclaved Prepeg ...
Posted 30th Jun 2020 at 14:32
Post #2735
Posted 30th Jun 2020 at 14:30
Post #2736
Posted 30th Jun 2020 at 14:31
Post #2737
Posted 30th Jun 2020 at 18:53
Post #2738
Posted 30th Jun 2020 at 18:55
Post #2739
Test fitted and bonded a 4mm carbon angle support plate on Rear bottom
Posted 5th Jul 2020 at 17:04
Post #2740
I’ve still got to move the steering column /Wheel over 50mm / 2 inches closer to the gear-lever Thumbs up
I can reach the control panel when harnessed in easily with a bent arm nowhere near stretched.....
Posted 5th Jul 2020 at 17:07
Post #2741
At its final resting place now ...just got the Gear change rod - going through it to sort ....
Posted 5th Jul 2020 at 17:10
Post #2742
Still got some other controls I’d like to fit to the centre console = possibly Steering column power steering adjustment and main isolater on / off button
Posted 5th Jul 2020 at 17:13
Ben_W
Formerly gpm
Post #2743
This is going to quite the machine....I'm seriously impressed with your template
Posted 5th Jul 2020 at 18:36
Post #2744
Hopefully Ben Thumbs up thank you
I really can’t wait to see it laser cut tomorrow m8 and then I need to get it bent and a couple of bits I shall weld on myself Thumbs up
Posted 6th Jul 2020 at 22:13
Post #2745
Today I thought I’d have a little change of front fascia of my control panel ...I really like the square coloured buttons but on my car and placed into the black Carbon surround I recon black plain Buttons will look better ...the Rallye boys need colours as they are bouncing around ....I shouldn’t get that on a smooth track ...Hopefully LOL
Posted 6th Jul 2020 at 22:17
Post #2746
No red surround anymore Thumbs up
Posted 6th Jul 2020 at 22:19
Post #2747
Here’s the sheet of stickers
Posted 6th Jul 2020 at 22:21
Post #2748
Here’s the inside of the main back of the Cartek = rubber gasket and complete new fibreglass fascia
Posted 6th Jul 2020 at 22:23
Post #2749
Small update
Lazer cut ( game changer ) out of 2mm steel for Steering support
Just got to get it bent / welded and polished and Nickel plated
Posted 7th Jul 2020 at 15:19
Post #2750
Nice work on the recent updates. Just a thought about having the steering support nickel plated, will bright reflections be an issue when driving in sunny conditions?
Posted 7th Jul 2020 at 18:14
