displaying posts 2576 to 2600 of 3423
Pages (137): first .. 103 [104] 105 .. last
Post #2576
Posted 6th Jun 2020 at 13:12
Post #2577
Posted 6th Jun 2020 at 13:11
Post #2578
I may once it’s made.... holesaw lots of holes in the Carbon to match the Gear-lever stand and the engine mount and I’m going to make a (stick out peak) over the Cartek panel to shield the lights on the buttons from the sun ...I can then see them on bright days Thumbs up
Posted 10th May 2020 at 12:58
eiei0
Post #2579
Just did the 104 pages in 2 sittings all I can say is WOW, Fantastic work and attention to detail,
Only negatives are It's a shame you drilled the Dash for the gauges now you are going with a digital dash, And I would have went with an electric fire extinguisher to avoid the horrible pull cables,
I think you prefer working on it than driving it :-)
Posted 13th May 2020 at 04:52
Post #2580
Hi Trevor thank you ...
Yep sometimes you do things with good intentions but you regret it Thumbs up
The car was bought for £1500 some 9 years ago to basically keep me alive through some very difficult / expensive dark divorce months ...it was never meant to evolve
The dash is mainly for Rev counter and gear indicator and most importantly G and lap times/ speed if I’m being honest....
The gauges on the dash are more for info setting up the car...
The DTA dash isn’t that big even though it’s expensive.....so to keep it from being too cluttered the dash gauges may end up being a bonus ...fingers crossed LOL
I have a electronic 360 gas Lifeline in the garage not fitted ( I’ll post a pic later ) but I prefer old school mechanical ...you know where you stand
Thank you again
Posted 13th May 2020 at 09:31
eiei0
Post #2581
Savage work Damien it's one of the best build threads I've ever seen, but I still don't know what size 16" wheels I need Big grin
Posted 13th May 2020 at 12:01
Post #2582
(Thank you Trevor) ...probably one of the most stupid expensive I guess Thumbs down ......loads more to come ...thank god I don’t have to spend anymore silly silly money maybe the Dry sump container is the next expense but not silly money
Don’t rush the wheels ...try and fit a set of your friends before spending your hard earned cash
Posted 16th May 2020 at 18:33
Post #2583
Good days work - playing with the car Thumbs up
Cut out the twin skin gear-lever stand and Stepped the inner skin so o could weld top and underneath flush ....
Posted 6th Jun 2020 at 13:10
Post #2584
Posted 6th Jun 2020 at 13:08
Post #2585
Posted 6th Jun 2020 at 13:07
Post #2586
3mm steel plate steeped so it’s flush
Posted 6th Jun 2020 at 13:06
Post #2587
Posted 6th Jun 2020 at 13:04
Post #2588
Welded on some wedges at the rear and smoothed off
Posted 6th Jun 2020 at 13:01
Post #2589
Everything’s starting to come together
Posted 6th Jun 2020 at 13:00
Post #2590
This is the underneath above the exhaust manifold before welding
Posted 6th Jun 2020 at 12:59
Post #2591
Been a messy day / bugger of a pain in the ass day -removing the original Satchell modified clamp and CV boot I originally fitted —-( far to well )many years ago which I bonded in also - won’t do that again....
Had to plasma a hole to the top left hand corner for the new box Sequencial gear selector rod to pass through to meet the gearbox selector ...
I’m going to make two steel plates and weld them back on to cover the NOW huge hole ...luckily the rod only goes in and out so only a small hole and tiny CV boot end needed on a tube ...
Also welded the plate into the recessed hole for the old gear-lever plate/ treated it and painted it and seam sealed it inside and underneath the car ...this won’t get seen as it’s under the Carbon control panel being made soon off my metal pattern ...
Because I’ve put my Gear-lever so far back next to the steering wheel ..the selector rod was 70mm to short ...so I just put a hollow tube inside both sides and welded / extended it with some zinc tube on the end -luckily I had the correct bore / size in my metal scrap box ...then etch primed it and sprayed the welded on ends....
Posted 17th May 2020 at 17:53
Post #2592
Posted 6th Jun 2020 at 12:57
Post #2593
Posted 6th Jun 2020 at 12:54
Post #2594
Posted 6th Jun 2020 at 12:52
Post #2595
Centre console gone away to be turned into Carbo Fibre
Posted 6th Jun 2020 at 12:51
Post #2596
Posted 6th Jun 2020 at 12:50
Post #2597
All sealed inside and underneath
Posted 6th Jun 2020 at 12:47
Post #2598
Posted 2nd Jun 2020 at 08:45
Post #2599
Post #2600
Top of the picture welded on 70mm piece
Posted 2nd Jun 2020 at 08:44
