Author Subject: vibration under braking
mocinim
Hi gents as above what would cause this brakes are all new pads and discs covered around 500 miles only under medium to heavy breaking after sprited driving any suggestions cheers
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 3rd Feb 2016 at 21:42
pad deposits on the disc probably.
Posted 3rd Feb 2016 at 21:49
Did you bed/run them in correctly ?
Not just go out & use them after fitting as normal ?
Posted 3rd Feb 2016 at 22:03
mocinim
Thought that maybe the case whats the best cure is it worth stripping and cleaning or will it wear its self clean
Posted 3rd Feb 2016 at 22:02
Posted 3rd Feb 2016 at 22:08
mocinim
No presumed they where already brought the car with almost 200 miles on the discs pads obviously not enough then put 300 miles into the stright away think it was a bit much for them advice on bedding in welcome
Posted 3rd Feb 2016 at 22:20
mocinim
Thats a great bit of detail and i probably cooked the disc's think they are pagid basic will replace with some brembo usless you guys advise any particular type brand advised
Posted 3rd Feb 2016 at 22:26
jeffers Forum Admin
I've got pagid discs on my track car with carbon Lorraine RC6 pads, I have never had any issues with the discs 'cooking' as u put it, what pads are they? I'm thinking friction material on the discs causing the issue due to cheap I pads not liking the heat of spirited braking.....
Team Running Engine again!
Team Negative Camber!
Posted 4th Feb 2016 at 09:39
mocinim
Cheers jeffers not sure of what pads they are will try changing them first any recommendations for road use with spirit Smile am thinking green stuff
Posted 4th Feb 2016 at 09:43
I use standard o.e.m pads at circa 200 bhp, not had any issues.
Posted 4th Feb 2016 at 10:32
mocinim
Cheers welshpug I was and have brought brembo for the rallye had no issues at all but euro have screwed up there site and are now not selling anything useful
I'm guessing they are oem drove it out this morning no issue once again it's a pleasure to drive under normal condition it's spot on but I do love some night time twistys and that when the shimmy begins not a good time to begin so thinking upgrade cheers guys
Posted 4th Feb 2016 at 10:55
I mean proper o.e.m as in they came in a citroen box.
Posted 4th Feb 2016 at 10:58
cully
I use Bosch pads from ECP/CP4less they work really well on spirited drives and day to day
but i can kill them and the discs on track but hay ho they are consumable items Wink
Posted 4th Feb 2016 at 11:10
mocinim
I mean proper o.e.m as in they came in a citroen box.[/quo
te]
Cheers welshpug noted Smile
Posted 4th Feb 2016 at 11:17
mocinim
Will check this out this car won't see a track so could be just the thing cheer cully
Posted 4th Feb 2016 at 11:18
hunt down the part numbers on servicebox and chuck them into ebay, I got mine for £18.
worth checking the early xsara vts part numbers as well as the gti6, also clio pads will fit on fresh discs.
Posted 4th Feb 2016 at 11:34
Also worth checking that the discs are mounted to the hun properly and there's not muck on the hub Thumbs up
Posted 4th Feb 2016 at 11:58
mocinim
Sounds like a good plan cheers fella
Posted 4th Feb 2016 at 12:09
mocinim
Going to investigate at the weekend am going to check the torque on everything
Its done 500 miles since a through rebuild i believe it was done really well but it time for its checkup me thinks plus am going to take the subframe back of to strip n paint
Posted 4th Feb 2016 at 12:13
mocinim
Want it looking more like this
mocinim has attached the following image:
Posted 4th Feb 2016 at 12:16
jeffers Forum Admin
I would avoid such things as green stuff pads, my one experience of them was they were pretty garbage and ended up with pad material all over the discs, as Welshpug says some genuine pads would do the trick.
Posted 4th Feb 2016 at 19:13
mocinim
Am currently on the hunt for some cant sign into servicebox not sure why dont suppose you have the part number for the correct ones
Posted 4th Feb 2016 at 19:16
Posted 4th Feb 2016 at 20:00
mocinim
Cheers ratty once again appreciated Smile
Posted 4th Feb 2016 at 20:03
mocinim
Discs n pads peugeot stock sourced cheers guys
Posted 5th Feb 2016 at 10:14
