Author Subject: wacky Speedo
shabusta
Help,
i have had this issue for ages and just palmed it off learning the gears and revs for speed.
my Speedo will work for a month with no issue or it wont work for a day,
every now and then it will just sit at 0 or bounce around for a bit then settle,
then randomly it will start telling me the correct speed again.
2001 Phase 3 Rallye (XSI)
Posted 28th Jan 2016 at 10:26
broken wiring, or knackered speedo drive.
Posted 28th Jan 2016 at 11:12
shabusta
Advice on how to inspect / fix?
Posted 28th Jan 2016 at 11:39
mocinim
1st pull out clocks inspect wiring could be a loose pin or clip at the back Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 28th Jan 2016 at 12:15
shabusta
Clocks? As in the time clock or the speedo / tach unit?
Whats the right name so i can find a thread on how to remove them.
Posted 28th Jan 2016 at 12:39
jeffers Forum Admin
Vehicle speed sensor....
Team Running Engine again!
Team Negative Camber!
Posted 28th Jan 2016 at 12:43
Yes this
Posted 28th Jan 2016 at 12:49
mocinim
Sorry clocks as in speedo dials (clocks !! Speed clocks as in clocking up speed)
British thing I guessSmile
Not the time clock
Posted 28th Jan 2016 at 13:05
mocinim
Believe the vehicle speed sensor to be on the end of the long drive shaft at the block end on the xsi
Smile
Posted 28th Jan 2016 at 13:07
More than likely the VSS, although could be a dirty connection on the plug which attaches to it.
Try unplugging it and then reconnecting it. On the '6' it is found on the passenger side of the gearbox where the driveshaft enters the box. Yes
The loom plug is protected by a silver foil type bag over the top of it.
If this doesn't solve it, then remove the instrument cluster and check the plug on the back of it. If either of these don't solve it then you'll more than likely need a new VSS unit. These aren't dear if you find you do require a new one.
Posted 31st Jan 2016 at 11:04
