Author Subject: Rear flexi port size
demondriverdan
Any idea what port size the rear flexis are? Need to redo the brake lines of a car this weekend and want to make sure I have all the parts ready. I think they're M10? Not using a compensator so would be straight from a T piece into the flexi
Rallye Race Car
Posted 26th Jan 2016 at 22:43
jeffers Forum Admin
Yep M10 Dan. Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 26th Jan 2016 at 22:45
demondriverdan
Cheers, thought so Smile Only thing left to figure out is what size I need for the bias valve my friend has!
Rallye Race Car
Posted 26th Jan 2016 at 22:46
mocinim
Are you changing from ph2 compensator to ph3
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 26th Jan 2016 at 22:59
demondriverdan
Taking compensator out all together as the car has a bias valve and it doesn't do much anyway!
Rallye Race Car
bias valves are often bsp taper threads unless specified as metric, youll probably need two male-male adapters to convert to m10x1.0 and use a female fitting on the pipe.
Posted 26th Jan 2016 at 23:18
demondriverdan
It's a Wilwood one that takes 3/8" so was just going to get 2 male unions to use. Normal bias valve I use takes M10 unions directly
Rallye Race Car
Posted 26th Jan 2016 at 23:24
