displaying posts 26 to 50 of 55
Pages (3): 1 [2] 3
Author Subject: my first 6
306 lover ryan
25mm
306 lover ryan has attached the following image:
Platinum gti 6 now the daily driver...1 problem so far...fuel economy!
Posted 24th Jan 2016 at 16:08
mocinim
Paste it clamp it will fix if you line it up correctly Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 24th Jan 2016 at 16:20
306 lover ryan
Yeah will do. Just a shame I'm stuck with a new exhaust that doesn't fit and an old one on the car.
Posted 24th Jan 2016 at 16:32
Yeah looks like a standard cat to me.
Posted 24th Jan 2016 at 16:47
306 lover ryan
Ryan must have sent me the wrong exhaust. It's a couple of mm too small in diameter. I had string around the cat and a quick cramp to squeeze them together but it wouldn't budge.
Posted 24th Jan 2016 at 16:50
306 lover ryan
Anyone have advice for fitting one of these?
I want to do it from underneath really.
Posted 30th Jan 2016 at 10:48
mocinim
Take the bumper off they can be a sod to line up easier to do if removed never tried whilst on the car
Posted 30th Jan 2016 at 11:01
only way is bumper off pal!
here's an FAQ --->Click Me<--
could do with being resilvered! Wink
Posted 30th Jan 2016 at 11:42
aaron6
How comes your fitting phase 2 fogs when yours should have crystals on.
Posted 30th Jan 2016 at 16:48
306 lover ryan
Post #35
My other fog light has lines on the lens so bought one to match
Posted 30th Jan 2016 at 17:41
306 lover ryan
Post #36
Thanks mate. Suppose it's coming off then
Posted 30th Jan 2016 at 17:45
Post #37
Should be clear ones as it's a phase 2.5/3 bud
Posted 30th Jan 2016 at 17:48
aaron6
Post #38
^^^this^^^
Posted 30th Jan 2016 at 18:22
306 lover ryan
Post #39
How can you tell? I assumed it's phase 2 because the fog lights had misted lenses lol
Posted 31st Jan 2016 at 08:59
Post #40
The way the throttle cable is looped,the fact that you have crystal headlights fitted and that you have colour coded sideskirts Thumbs up
Posted 31st Jan 2016 at 09:15
306 lover ryan
Post #41
Need some more advice guys...
Got under the front today but don't have the right socket so didn't change oil just yet, but did change air filter.
The old one had oil over it and there was oil in the box. Any thoughts to why?
Some kind of steering piston? Seems to be leaking.
The worst part was the oil leak coming from where the engine joins the transmission toward the back.
Also oil up infront of engine, near where the oil filter is located.
Pics to follow
Posted 7th Feb 2016 at 11:32
306 lover ryan
Post #42
Up front
Posted 7th Feb 2016 at 11:29
306 lover ryan
Post #43
Worrying bit
306 lover ryan
Post #44
Another angle
Posted 7th Feb 2016 at 11:30
306 lover ryan
Post #45
Steering piston leak
Posted 7th Feb 2016 at 11:31
306 lover ryan
Post #46
Any help greatly appreciated
Posted 7th Feb 2016 at 11:33
mocinim
Post #47
Up front
Power steering pipe high pressure pipe leak at a guess pic is not so clear
Replace it
Posted 7th Feb 2016 at 12:28
mocinim
Post #48
Ram is leaking replace it
To change the pipe un power engine remove battery allow 20mins from last run for system be be clear of pressure then un bolt n replace
The steering ram
May require the subframe to be dropped off pull the rack out switch n replace
Im not sure if it can be removed without dropping the rack would of thought not
Ram
Requires the removal of two fluid pipes and two ram anchorage bolts one 17mm or 19mm n one star drive cant remember the size
If your subframe has not been off it will require a new set of bolts and the ability to drill n tap out the old most likely they will be rotten
Posted 7th Feb 2016 at 12:38
aaron6
Post #49
Changing the ram cam be an arse too. Also they are no longer available so may pay to see if you can find a non leaking 2nd hand one from here
Posted 7th Feb 2016 at 12:50
306 lover ryan
Post #50
Close up of worrying oil leak
Posted 7th Feb 2016 at 16:16
Pages (3): 1 [2] 3
