displaying posts 1 to 25 of 54
Pages (3): [1] 2 3
Author Subject: VTS rack fitted - odd behaviour...
Chr1sch
Hi all
Well after a 2 month saga/nightmare my phase 2 vts rack is fitted...
The turn in and general 'alertness' is frankly epic, however it is also doing something rather odd that I hope you can advise me on...
So, I've had a 2nd hand low mileage vts rack fitted with new track rod ends, mated to my existing setup. Sadly the high pressure rail was ruined by the supplier so we had to have part of it repaired which was effectively replaced by a well known local high pressure hydraulics company...
Anyway, looks great, really nice fitment etc, however I'm finding when holding anything more than a constant 1/4 lock in either direction (e.g a roundabout) there is an odd almost tugging sensation at the wheel (like a strong self centering type motion)
The old standard rack didn't do this, it's not dangerous but doesnt feel great, any idea what could be causing it?
Much appreciated, this has been a very long and expensive saga so just want to sort it out :-(
Posted 23rd Dec 2015 at 22:51
sounds like still a bit of air in the pipes
Posted 24th Dec 2015 at 00:21
tvrfan007
How did you bleed the rack? Did you go lock to lock multiple times?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 24th Dec 2015 at 07:36
I always fancied this upgrade!
are they a pig to fit?
Posted 24th Dec 2015 at 07:38
Chr1sch
I didn't bleed it the garage did...well worth it the turn in is incredible!
Thanks I'll get them to bleed again
Posted 24th Dec 2015 at 08:02
Bleeds it's self
Posted 24th Dec 2015 at 08:19
Chr1sch
Do explain....I.e it will get better or I have another issue?
Posted 24th Dec 2015 at 08:36
pug_306
Sounds like a restriction in a pipe.
1992 205 GTi6
205 Turbo 340bhp
Posted 24th Dec 2015 at 09:02
Chr1sch
Balls I feared it may be that, the high pressure rail was mullered so we had to replace a section of it, hope that isn't what is causing it :-(
Posted 24th Dec 2015 at 09:06
Source a cheap second hand pipe and swap it over.
  • Posted 24th Dec 2015 at 09:34
    pug_306
    Did you get the kit off me ?
    1992 205 GTi6
    205 Turbo 340bhp
    Posted 24th Dec 2015 at 09:45
    Have you checked the uj on the steering colum ? Sometimes they dry out ?
    Posted 24th Dec 2015 at 09:53
    tvrfan007
    bigbadbowen wrote:
    Bleeds it's self
    You should go lock to lock a few times but yes the air will extract itself.
    Try reworking the pipe if there is any obvious damage.
    I'm Si btw Tee hee
    Posted 24th Dec 2015 at 10:00
    Chr1sch
    Not sure mate, I'm not going to start slagging anyone off, the chap I dealt with was pretty reasonable in the end so I just want to get it fixed one way or another
    I will get the Uj checked, ive found it next to impossible to source a replacement full hp hose and frankly don't have the time to get it all replaced etc, in the end it's cost me a small fortune lol
    Posted 24th Dec 2015 at 10:11
    scrapped a hp hose last week.
    Posted 24th Dec 2015 at 10:12
    Chr1sch
    Xsara vts one!? :-(
    Posted 24th Dec 2015 at 10:20
    demondriverdan
    I just picked up a ph2 rack from Ryan without the pipes so hopefully you can have those ones Smile
    Rallye Race Car
    Posted 24th Dec 2015 at 11:51
    Chr1sch
    Ah cool thanks for the heads up :-)
    Posted 24th Dec 2015 at 12:04
    Chr1sch
    Guys we're drawing blanks, pipework all looks good, you don't have to change the pas pump too do you?!
    Posted 6th Jan 2016 at 07:48
    no, but it might be dead.
    Posted 6th Jan 2016 at 09:37
    demondriverdan
    I've got a couple spare if you need one
    Rallye Race Car
    Posted 6th Jan 2016 at 10:30
    Chr1sch
    Thanks Dan, would you agree that if the wheel movement (steering wheel) fluctuates with revs then the pump has coincidentally died?
    Posted 6th Jan 2016 at 11:30
    Chr1sch
    Posted 6th Jan 2016 at 11:31
    Chr1sch
    Posted 6th Jan 2016 at 11:33
    demondriverdan
    Sounds like it might have done. I know that if I turn the wheel on my road car the revs change as the pump puts load on the engine.
    Could be that there was a blockage or something not right in the new pipes and it caused damage to the pump?
    Rallye Race Car
    Posted 6th Jan 2016 at 13:06
    Pages (3): [1] 2 3
