displaying posts 1 to 25 of 38
Author Subject: Driveshaft seal issue
alcon
Can someone tell me if this rubber washer thing should sit right inside the speedo housing as it doesn't look like it will fit. If it doesn't then where does it go. Currently got gearbox oil running out so clearly something's not put back the way it's meant to be.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 15th Nov 2015 at 15:48
tvrfan007
I suspect your driveshaft seal is too far in or damaged.
The seal sits behind that big rubber donut. It needs to sit flush with the three upstands on the face, or at least that's how i did my last one.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 15th Nov 2015 at 15:51
alcon
It was a brand new seal I fitted so hopefully not damaged but too far in may be possible. So does the rubber ring just sit where I've got it in the photo?
1999 Rallye (black)
Posted 15th Nov 2015 at 16:02
jeffers Forum Admin
Rubber thingy sits just outside of box, it has nothing to do with the seal. The seal is damaged/ badly positioned or something.....Unsure
Team Running Engine again!
Team Negative Camber!
Posted 15th Nov 2015 at 21:55
tvrfan007
The rubber donut is for the driveshaft, not the gearbox.
I can only suppose it's either a cheap seal or it's in a bit far. Smile
I'm Si btw Tee hee
Posted 16th Nov 2015 at 08:45
mocinim
Whats the doughnut for
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Nov 2015 at 10:56
just a dust cover protector thing for the seal.
Posted 16th Nov 2015 at 11:04
mocinim
Cheers welshpug
Posted 16th Nov 2015 at 11:06
The seals themselves should be flush with the housing, I usually use a rubber mallet to knock them home to avoid damaging them.
Regarding the donut, as said its just a dust seal for the main seal, sits as you have it in the photo. Smile
Posted 16th Nov 2015 at 11:32
early type seal should not be flush.
Posted 16th Nov 2015 at 11:36
LOL not this old chestnut
Posted 16th Nov 2015 at 12:09
What would you call early type? I do tonnes of these both sides always change them when ever I do a clutch on anything French and always gently and evenly tap them flush. Never had a single one come back leaking. Did one on my red rallye Saturday too.
Posted 16th Nov 2015 at 12:31
cully
this!
dont push the seals in too far or it blocks the oil drain from the back of the seal forcing oil past the seal to leak Wink
Posted 16th Nov 2015 at 12:42
Early type being the white tooth version
Posted 16th Nov 2015 at 16:51
jeffers Forum Admin
I always use the early type seals an tap them flush, never have they leaked.
Posted 16th Nov 2015 at 19:37
Well they shouldn't be flush fitted just slightly proud
Posted 16th Nov 2015 at 19:42
jeffers Forum Admin
If that's the way they're supposed to be then fine, I was merely pointing out that I've not had an issue fitting them flush! Thumbs up
Posted 16th Nov 2015 at 20:43
alcon
The ones I bought from Peugeot were slightly different to the ones I took out. The original ones had a white toothed ring on it whilst the new ones didn't. I thought I had fitted it in the correct location however that would appear to not be the case. When I get back to it, I'll take another photo of the seal behind that rubber ring and you can all tell me if I've got it wrong.
1999 Rallye (black)
Posted 16th Nov 2015 at 21:20
The new version from pug are flush fit
Posted 16th Nov 2015 at 21:32
alcon
I took this photo as a reminder of which way the clutch fork went back in and I'm pretty sure that was the new seal I had put in there....so this is too far in? Should it be flush with the outer casing?
1999 Rallye (black)
Posted 16th Nov 2015 at 21:44
Error are you sure there's even a seal in there? Either that or you e managed to smash it right in there....
Posted 16th Nov 2015 at 22:48
alcon
I take a better look tomorrow as ts now back on the car.
1999 Rallye (black)
Posted 16th Nov 2015 at 23:06
its back to front.
Posted 16th Nov 2015 at 23:31
Now you mention it could well be lol therefore it's not gonna work to we'll LOL
Posted 16th Nov 2015 at 23:34
School boy error
Posted 16th Nov 2015 at 23:40
