displaying posts 26 to 38 of 38
Pages (2): 1 [2]
Author Subject: Driveshaft seal issue
Loool
Posted 16th Nov 2015 at 23:48
Doh
Yep, that's in back to front...
Posted 17th Nov 2015 at 00:14
alcon
Ah feck, that means I need to pull the shaft back out somehow to remove/reverse the seal! Just when I thought I was nearly finished.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 17th Nov 2015 at 08:18
Yeah, the issue you're going to have is trying to remove that seal will almost certainly damage it, so you'll need a new one for sure. Thumbs up
Posted 17th Nov 2015 at 09:47
alcon
I take it then the seal is different on both sides? ie. how do I know which way in it goes?
1999 Rallye (black)
Posted 17th Nov 2015 at 09:52
They're lipped, they only seal properly in one direction, like most oil seals.
Posted 17th Nov 2015 at 10:40
alcon
Cheers guys, I've ordered a new one with the expectation that the old one will possibly get mangled getting it out.
1999 Rallye (black)
Posted 17th Nov 2015 at 10:42
Yes, the housings are different sizes on each side so they are different size oil seals.
As Phillipm says, the 'lip' of the seal fits on the outside as you're looking at the housing.
Posted 17th Nov 2015 at 11:05
alcon
Sorry I didn't mean are the seals different on both sides of the housing, I know one is bigger than the other...is there a certain way round the seal goes in? I only have a leak from the drivers side.
1999 Rallye (black)
Posted 17th Nov 2015 at 11:07
Post #35
Flat side on the outside edge of the box
Posted 17th Nov 2015 at 11:09
alcon
Post #36
It's ok, I think I know what you mean
1999 Rallye (black)
Posted 17th Nov 2015 at 11:14
alcon
Post #37
My new seal arrived today and going to fit it tonight. Just so I'm absolutely certain here, the seal goes in this way......
and not this way.....
Also, can someone confirm if the outer face of the seal should be flush with the housing or slightly proud?.....there seems to be conflicting opinions on this
1999 Rallye (black)
Posted 19th Nov 2015 at 18:36
Post #38
Yes top pic is correct way. Thats newer type seal just fit it flush.
Make sure you tap it in with a nice fitting socket or something dead flat to push it in by the outside and not damage the inside.
Posted 19th Nov 2015 at 19:28
Pages (2): 1 [2]
