displaying posts 1 to 25 of 44
Author Subject: An engine that will last!!!
sctyres
So on Sunday I blew my engine up at Mallory Park - 3rd one in 6 months!
Therefore I'm after one that will take the abuse and not let go when I'm enjoying myself! - would have easily beat Mr Wells in his pink rallye if only that had lasted long enough also!
Running jenveys, lightened fly wheel and full spookz map, but she's still slightly under 200 bhp so must be my engine building skills, or my driving at fault! Either way- it's getting expensive and depressing changing them as often as I am!
Failing selling me the right price of kit for the job- I'm happy to build another, and any advise or parts would be welcome, head is good, it's blowing past the rings so needs a full bottom end build at the very least!
Please help me before I end up breaking it and buying a rover!
www.sctyres.com
Posted 10th Nov 2015 at 18:53
How did you blow it up ?
Posted 10th Nov 2015 at 19:21
sctyres
Too many revs I think- was pushing it hard, really hard, as was chasing a focus st running 280 break- out cornered him on every bend but couldn't pass him on the straights- got to 7000 in 4th half way down the straight but like a cock I held her there for a touch to long whilst looking about- smoke ensued- a lot of smoke!
www.sctyres.com
Posted 10th Nov 2015 at 19:45
step 1, stop using sPOOx.
step 2, learn that rovers are utter w**k, unless its a v8.
step 3, realise that even the newest gti6 is 15 years old, you can never expect them to last that long if you just chuck them in and give them death.
did you have different cams In it? if not, it will be nowhere near 200 bhp, 7k rpm is nothing though, stock limiter was 7450 on early ecus (though peak power was 6500 )
what exactly has failed on it?
Posted 10th Nov 2015 at 20:09
Well said Mei ....
Who's been mapping them ?....100% bet it's slightly lean at 7000+ Bang !!!!!!
Posted 10th Nov 2015 at 20:30
Stop using spoox
7k should be fine on a gti6 engine
Get someone to build the engine that can do it properly
Get the mapping done by someone who can do it properly ?
Posted 10th Nov 2015 at 21:02
eddy_gti6
I have a good engine in my rallye. Complete with everything and box. £400
Posted 10th Nov 2015 at 22:07
fatlapit
Then wat u gonna use eddy??
fatlapit
s**t man my turbo motor can stay at 7k all day
Posted 10th Nov 2015 at 22:08
eddy_gti6
I will worry about that when the time comes, won't be any time soon Laugh my ass off
Posted 10th Nov 2015 at 22:09
fatlapit
Lmao nutter
Posted 10th Nov 2015 at 22:11
eddy_gti6
More important things to worry about than a running engine at the minute haha
Posted 10th Nov 2015 at 22:12
My engine is completely standard internally and has put up with over 3 years of abuse running 100bhp more than standard.... decent map decent oil and oil cooler and it should take 7K all day long. The limiters not till 7650 on mine and it's been hit plenty of times.
Posted 11th Nov 2015 at 17:08
What temperature is the oil getting to out of interest, and what oil is being used?
Posted 11th Nov 2015 at 17:43
demondriverdan
Should definitely have an oil cooler for a track car. If not and your oil temps are getting high, that could be the problem.
Rallye Race Car
Posted 11th Nov 2015 at 19:49
sctyres
have a cooler fitted- and the oil wasn't getting overly hot, I was just guessing at 7000rpm due to having no working counter at the moment- it was on the limiter I know that much, but not for long enough to expect it to die!
the engine was rebuilt using mostly pre used parts from my first two, with new bearings ect - at the time I was running short on funds but needed her running asap so it was a bit of a bodge up I guess!!
happy to take your engine if its all good eddy - what kind of miles are on it? and where abouts in the world would it be? know plenty of haulage companies so collection is no issue
www.sctyres.com
Posted 11th Nov 2015 at 20:39
sctyres
why does everyone dislike spoox by the way? ive used them quite a bit during the build - as they took me on my first track day to donnington when I was trying to sell the car, as had already sold my lovely diablo one and had no love for the china I had kept- id bought this one for scrap money just because I had the space to store it!
www.sctyres.com
Posted 11th Nov 2015 at 20:42
expensive and dubious quality work.
Posted 11th Nov 2015 at 21:21
Spoox are the motoring equivalent of aids,best avoided Thumbs up
Posted 11th Nov 2015 at 21:35
eddy_gti6
I have never used an oil cooler on track before and never had any issues with oil temp.
Posted 11th Nov 2015 at 22:08
Depends what you class as a temperature issue.
Posted 11th Nov 2015 at 22:11
barrym
Really? What sort of oil temps do you see on tracK?
Black Rallye occassional toy
Posted 11th Nov 2015 at 22:18
fatlapit
Oil temps and the severity of the temp depends on the oil.
For example a normal oil like comma semi 10 40 will struggle after 100 degrees to retain its properties.
But
More refined oils can go up as far as 115 degrees and be perfectly ok.
Posted 11th Nov 2015 at 22:49
fatlapit
You get what you pay for.
A good race-spec synthetic should be good with brief periods of 130*c bulk/sump temp and 150*c peak (bearings and head), but with the bearing loadings being higher then normal you'd want to be well on the safe side - keep it around the 100-110 area.
Posted 12th Nov 2015 at 12:29
