displaying posts 26 to 44 of 44
Pages (2): 1 [2]
Author Subject: An engine that will last!!!
demondriverdan
I've always aimed for 100 and I get that pretty consistently with the 16 row oil cooler. That's with Fuchs Titan Pro S 5W40 oil
Rallye Race Car
Posted 11th Nov 2015 at 23:20
Ben_W
Formerly gpm
Oil temp isn't the issue here. Last two engines grenaded in the same way. First didn't have oil cooler, second did. Yet both blew the bottom end. First one was old and smoked a bit anyway. Second was relatively fresh.
That engine needs to come apart Luke to figure it out. I suspect it's blown a ring or two. Why, is another matter. Whatever has failed pressurised the sump for it to blow all the oil out of the dipstick tube or down the exhaust. For that to happen, its got to have come up a cylinder past the oil control ring. A compression test should tell you
Posted 11th Nov 2015 at 23:28
eddy_gti6
barrym wrote:
eddy_gti6 wrote:
demondriverdan wrote:
Should definitely have an oil cooler for a track car. If not and your oil temps are getting high, that could be the problem.
I have never used an oil cooler on track before and never had any issues with oil temp.
Really? What sort of oil temps do you see on tracK?
15minute sessions at croft in my rallye barely seen around 90, and my old Astor on open pit lane didn't see much more than that. And I drive them hard on the road too with no oil temp problems.
Posted 12th Nov 2015 at 00:13
cully
my old engine regularly saw 125 on the dash gauge on hard driving but that had a faulty oil take off plate for the cooler
oil temp didnt kill this engine with bearing failure
with that problem fixed ive not seen 100 on the new engine
Posted 12th Nov 2015 at 09:03
aaron6
Mine saw 125° at brandshatch in a 20mins session and that was with a 13 row cooler and thermostatic plate
Posted 12th Nov 2015 at 11:30
fatlapit
track work u need a 19 row 235mm cooler
Posted 13th Nov 2015 at 14:44
Twangy
my suggestion on this is compression test and strip the engine to see what has caused problem ,youll soon see the problem what caused this
wayne mcardle
Posted 13th Nov 2015 at 15:05
aaron6
Being turbo'd are you not running higher combustion temps thus requiring a 19 row? As demondriverdan said his n/a racing car is fine on a 16.
Posted 13th Nov 2015 at 20:41
fatlapit
I think most track type cars regardless of induction type run the biggest cooler they can utilise.
Posted 13th Nov 2015 at 22:30
Post #35
I was using a 13 row and had the same temps as you on track Aaron. A 19 row solved the issue though.
Posted 14th Nov 2015 at 09:35
Chr1sch
Post #36
I believe this is a 13 row? (I just counted the lines lol) and I got 130+ On track without it (one session)
And never over 100 now regardless of how hard I drive it or temps generally on the day
Posted 14th Nov 2015 at 11:19
cully
Post #37
16 row here Wink
Posted 14th Nov 2015 at 12:21
Post #38
My old setup. 2x13 row 235mm coolers. Couldnt get temps above 100c even in 30+c weather conditions.
Posted 14th Nov 2015 at 13:01
Post #39
Row row row your boat........
Posted 14th Nov 2015 at 13:47
Post #40
Laugh
Posted 14th Nov 2015 at 14:22
martinh
Post #41
Looking at those pictures of the oil coolers what is the correct way to fit them, with the pipes coming in the top or the bottom?
Posted 14th Nov 2015 at 16:23
cully
Post #42
i always wondered this i never found a definat answer
pipes top no airlocks in the cooler maybe!
pipes bottom easier to drain oil from cooler maybe!
anyone??
Posted 14th Nov 2015 at 17:07
Post #43
Pipes in bottom, easier to change oil, no old oil left in coolers.
Posted 14th Nov 2015 at 19:16
Post #44
Mine is mounted vertically so sorts both issues Wink
Posted 15th Nov 2015 at 07:51
Pages (2): 1 [2]
