displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: Now enjoying my 306
RallyeP6
Had a brilliant 3 days on the Yorkshire Dales and Moors, twisty winding roads, steep inclines, popping and banging from the exhaust, great scenery.
Throttle Bodied Peugeot (TBP)
consists of:
Throttle bodies by Jenvey
ECU DTA E48
Air filter Pipercross
Injectors standard
Engine standard
Head rebuilt by Rich W and Co
Wiring and build and initial mapping by Me
Proper mapping by Road n Track
Exhaust Magnex (but could do with a quieter back box!)
Has been totally reliable over the 900 mile trip, even though i took all the tools and spare bits i might have needed if i got into trouble.
So to many more road trips this summer and next step is the Maxi Kit.
Posted 8th Apr 2015 at 22:19
jeffers Forum Admin
Nice looking motor mate, what management is it running?
Team Running Engine again!
Team Negative Camber!
Posted 8th Apr 2015 at 22:25
RallyeP6
Its an old DTA E48, that i bought back in 2000, previously used in my Citroen Bx Gti turbo.
Posted 8th Apr 2015 at 22:42
RallyeP6
Sun was out the other day, so a bit of a tidy up, now trying to fit the oil catch tank where the air filter used be.
Posted 27th May 2015 at 23:25
RallyeP6
While cutting away the wheel arch I was thinking of how much time, effort, resources and care have gone into making this thin sheet of steel look perfect. And then I carried on cutting with my little Dremel.
Trial fitting of front wings, getting them to align properly wasn't too difficult just the parts under the headlamps kept getting caught and scratching the lens.
At the moment got the smell of resin and hardener in the living room as I repair the kevlar bumper, courtesy of Ross, cheers mate.
Posted 14th Mar 2016 at 22:37
Any more progress??
Posted 11th Apr 2016 at 12:26
RallyeP6
Progress is happening in leaps and bounds, NOT!. The car looks in a bit of a sad state at the moment, all different colours, filler and fibreglass here and there. The front bumper is in the living room at the moment and going back on this evening. Hopefully I will get the bodywork finished in a couple of weeks, weather permitting and then off to paint. Suspension, driveshafts and wishbones to sort out this week.
Will take a picture later this evening.
Posted 12th Apr 2016 at 09:34
RallyeP6
Filling, sanding, filling, sanding, filling sanding, priming, sanding, filling, sanding, cutting, sanding, filling, sanding etc etc etc............
That's all that I have been doing the past few weeks, any way getting better at it, though not as good as I used to be. I remember making a better job of things when I was (a bit ) younger.
So front bumper is primed but still needs a bit of correcting and an aluminium mesh to glue in place.
Wings need cutting and re adjusting, sills need sanding down and the rear arch edges need cutting back by the door shut and then more filling and sanding.
My coilovers and top mounts should arrive tomorrow though from Bridgecraft, looking forward to that, then maybe fitting on Saturday, if all goes to plan.
Posted 27th Apr 2016 at 23:27
Getting there Rouben Thumbs up
Keep the updates coming m8
It's starting to look great !
Posted 28th Apr 2016 at 00:34
RallyeP6
Thanks for that, yes it was only yesterday that I started to feel that it was finally taking shape, just waiting for a mate to give me a quote for the paint.
I am aiming for end of May 'finish line', just in time to take it to the WRX championship at Lydden Hill (to watch the race).
Posted 28th Apr 2016 at 10:15
superchargedblack1997gti6
Looks awesome mate great work Smile
Posted 28th Apr 2016 at 11:00
Coming along rapidly keep up the good work! Thumbs up
Posted 28th Apr 2016 at 12:24
Thumbs up
Posted 28th Apr 2016 at 13:15
RallyeP6
A BIG THANKs to you Ross, the bumper is looking half decent now, duct tape is long gone and means I don't need to buy a new one.
My coilovers have turned up plus a 306 gti shaft and C5 shaft to dismantle and compare.
Posted 28th Apr 2016 at 13:31
Nice work Thumbs up
Posted 28th Apr 2016 at 16:40
RallyeP6
Fitted a 306 Gti6 outer cv joint to a Citroen C5 drive shaft, which gives a 30mm extension. Now need to get a second hand C5 off side drive shaft. The cv joint clip is a spare just taped to the drive shaft so I don't loose it.
Posted 9th May 2016 at 18:22
Tarmac terror
Where did you get that Maxi kit??
*ponders*
LOL
TT
Posted 10th May 2016 at 11:00
RetroPug
You can get FG ph.1 and ph.2 maxi kits here:
http://www.maximotorsport.com/products.php?directory=products/Peugeot/Peugeot%20306/306%20Maxi%20Bodykit%20Phase%202
Posted 10th May 2016 at 12:09
Tarmac terror
Hmm.....excellent!!!
Food for serious thought I think!!! Always fancied one of these although the stupid amount of front arch clearance keeps putting me off.
What does the Ph1 and Ph2 refer to?? Is it KIT phase/version or CAR phase/version??
TT
Posted 10th May 2016 at 15:09
RallyeP6
That is where I bought the kit from, although they do originate from (I think) MC Racing or Rallying in France.
Phase 1,2 and 3 Differences are the front bumper as far as I can tell.
Posted 10th May 2016 at 15:41
I wish you guys would learn how to do clickys LOL
Posted 10th May 2016 at 16:16
Cjwatson27
Do you have to cut away the rear arches ? Or can you just bond to them ?
Posted 10th May 2016 at 22:20
RetroPug
TT
The front bumpers are different, not sure about the rest of the kit. They can probably be fitted to either phase of car but basically it's for the ph.1 or ph.2/3 cars, but much in the same way you can convert the standard cars to other phases by swapping bodywork I bet these fit both.
The arch clearance is because it's a rally car...
Posted 10th May 2016 at 23:28
RallyeP6
I only cut away what was needed on the rear arches, enough to the lower the car and space out the rear wheels by 40mm. Though you could if you wanted to, cut all the way to the rear window, a bit like how Ross or Ash have done it.
Posted 11th May 2016 at 13:07
Cjwatson27
Cheers that's what I though you were doing. You running spacers on the rear?
Posted 11th May 2016 at 13:13
Pages (3): [1] 2 3
