displaying posts 26 to 50 of 51
Pages (3): 1 [2] 3
Author Subject: Low boost or Throttle bodies
jeffers Forum Admin
Jenvey do sell all the required bits to fit an ICV, but as has been said before well setup you won't need it.
Team Running Engine again!
Team Negative Camber!
Posted 30th Mar 2015 at 17:12
pebbles167 wrote:
Bodies would be my choice. But there is no denying that 'Bang for Buck' a low boost setup is the way to go.
debatable, given most only pull mid 230's and add make the car weigh more than stock, where a TB setup adds no weight at all, yo could cam and t-b a 6 for less than a charger on its own...
Posted 30th Mar 2015 at 18:32
rallyeash
I've been a passenger in a stock gti6 and gone past a LBSC track car at Llandow... Owner wasn't overly pleased!
309 3dr K20 Type R
Posted 30th Mar 2015 at 19:39
orta
Bodies are cheaper as well no?
Don't you only get 180-190 bhp from them? Against 230-240 from a supercharger
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
I'm over 200 with mild cams, with the satchell inlet mid 190's on a stock engine is ballpark figures.
Yes bodies are well cheaper.
Posted 30th Mar 2015 at 20:07
pebbles167
Hmm. The bodies themselves might be, but installing it all and getting it running right is going to be pretty costly ins't it?
As i said before, bodies would be my choice. I love a high output NA engine, but for an instant 70 - 100 bhp, a supercharger will be fairly cheap. Second hand setups are going for under £2k.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 30th Mar 2015 at 20:38
Get some lairy cams to go with the throttle bodies. Shameless plug Laugh
http://www.306gti6.com/forum/showthread.php?id=148924&page=last
Posted 30th Mar 2015 at 20:51
installing cost me nowt, mapping cost £300.
Posted 30th Mar 2015 at 21:33
Did they know what the pedal on the right does at all? My low boost would eat any standard 6 without trying (and regularly does) pulls off the clock without slowing down, saw off 3.0 twin turbo supra up to 120mph when he gave up while running less power than I am now with 3 people in the car a sub in the boot and full interior.
Yes it adds weight particularly up front but even keeping elec windows and sunroof full dash and not the lightest bucket seats with heavy solid lower strut brace and thick harness bar it's around 1060kg.
Not much can see it off in a straight line or the twisties. I've worked on and driven a lot of boosted cars while at a Mitsubishi / Japanese dealer for 7 years and most wouldn't keep up.
There's absolutely no arguing that bodies rules easily on noise but you'd have to do and spend a lot more to an engine to make low boost power with bodies. E.g bore/stroke rods pistons lifters cams mapping ecu and loom etc etc
The downside to a charged track car is the charger won't last forever and is a massive outlay to replace new. Boddies can't really go wrong.
If you want best power for money go charged.
If you want an awesome soundtrack a bit more power and keep the reliability then bodies Thumbs up
Posted 30th Mar 2015 at 22:27
Post #35
Out of interest guys what sort of torque figure does a 230-240bhp N/A setup produce?
Posted 30th Mar 2015 at 22:40
Post #36
depends on the cams and capacity, I know DrSarty was about 190+ LBFT with quite a fat curve.
Posted 30th Mar 2015 at 22:53
Post #37
Trumpets FTW!
  • Posted 30th Mar 2015 at 23:25
    Post #38
    dangti6 wrote:
    Trumpets FTW!
    I do miss the bark mine had while standard ish with K&N and an inlet res bung sounded epic and turned heads massively.
    Posted 30th Mar 2015 at 23:39
    Post #39
    That is nothing compared to the bark of a J4RS on bodies.
    Posted 31st Mar 2015 at 12:19
    Post #40
    Must Admit ...I'm a Bodies groupie Whistle
    Posted 31st Mar 2015 at 14:38
    Post #41
    I've heard the metallic green 205 that pug1off built that's running 280bhp on bodies going up the strip at Santa pod. Noise is epic
    Posted 31st Mar 2015 at 14:53
    Post #42
    not a fan of that one tbh, its all revs and no grunt, last I heard form the owner when he posted on the 205 forum he said it was over 300 bhp, but it was off the Norhampton RR running to a stupid RPM not in a 1-1 ratio, so fudge factor was massive....
    he started threatening and getting all keyboard warriory then Laugh my ass off
    Posted 31st Mar 2015 at 15:03
    Post #43
    Lol yeh you do have to rev the nuts off it as only makes power at very top end. They did the same spec engine in a red rallye same power figures 280ish that was in PFC mag some time ago with white compomotives on. Seen it at pugfest too. Think I remember having an argument with one of the 2 car owners saying how in usable the power was bing 100% top end and I questioned the reliability running that sort of n/a power. They then turned all keyboard warrior too LOL
    Posted 31st Mar 2015 at 16:15
    rallyeash
    Post #44
    Yep how actual often are you just before the redline! A couple of seconds before dipping the clutch, grabbing another gear and back down to 5k again.
    4.5-6.5k is your ideal usable power band.
    Funny how Pug 1 off engines are all in show cars... I'd like to see one of there's in a race series. That'll sort the keyboard bashing out.
    309 3dr K20 Type R
    Posted 31st Mar 2015 at 16:30
    rallyeash
    Post #45
    Wasn't the corrected flywheel power something like 60hp above the WHP.
    309 3dr K20 Type R
    Posted 31st Mar 2015 at 16:33
    Post #46
    Ash I love the sound of your car & love every time I see it each year something major has been upgraded Thumbs up
    What's Next for yours as if enough hasn't been done already Whistle
    Your m8s Red 205 is rapid also !!!!!
    Cant wait to see Mei in his Also .....Thumbs up
    I think it's looking like LB Guys Big grin ....only because I feel Bodies need a 2.1/2.2 by Mei to give those LB boys a Run & I've not got that kind of money at the mo !
    I'm going to hopefully go LB & then save up & sell it for 2.1/2.2 special with Bodies ?
    Well that's the plan LOL
    I think my 3J deserves it Razz
    Posted 31st Mar 2015 at 18:43
    Post #47
    Nothing beats the sound of a set 50mm tbs running at 8.2k revs
    Posted 31st Mar 2015 at 18:46
    blandy
    Post #48
    Take a look at Simon James in a saxo vts, Jason Newman in a mi16 engined 306 and there was also Gordon mason in a mi16 205 all pug 1 off built cars that run in the tricolore trophy in last few years and very reliable and competitive.
    Posted 31st Mar 2015 at 18:53
    Post #49
    AGREE Thumbs up
    Some of the Pug1off stuff looked good ...not qualified to comment on there quality or reliability Whistle
    Posted 31st Mar 2015 at 19:54
    Post #50
    last I know of simon he was 3 seconds a lap off will diclaudio and another sb engined 106 LOL
    Posted 31st Mar 2015 at 20:07
    Pages (3): 1 [2] 3
