Author Subject: can you identify this sensor
Mossy1985
Just started stripping my engine on the engine stand and cleaning it up ready for paint, when i got a bit carried away and i caught a sensor. It is on the front of the block more towards the right than left and is about half way down. It has a little rubber boot over 2 soldered probes and i managed to snap.one of the soldered joints. Will be able to repair or if not fit the one from.my engine that is currently fitted, but was wondering what sensor it is? It has a dark green plug on it 2 pins?
Posted 20th Mar 2015 at 18:13
Well done guys Thumbs up
Posted 20th Mar 2015 at 20:12
Sounds like oil level sensor but been a while since I've seen one to be honest
Posted 20th Mar 2015 at 19:41
1. cam position sensor?
2. water temp sender ( guage/warning lamp)
3 water temp sender ( ecu)
4. ?????
5,oil level sensor
6.knock sensor
7.oil pressure
8.oil temp sender
(all copied from a 205gtidrivers thread)
Posted 20th Mar 2015 at 19:56
Mossy1985
Cheers Rikky its number 5, very poor design of sensor if you ask me
Posted 20th Mar 2015 at 20:03
Mossy1985
Although common sense would would make you think 5 and 8 would be the other way round purely on location?
Posted 20th Mar 2015 at 20:06
The oil level sender is like a long tube that goes down into the sump so it detects the oil level.
Number 4 was just a blanking plug on both my gti6 engines iirc, although on the track car i've used an aftermarket oil pressure sensor in that position so i can see the pressure on the dash.
Posted 20th Mar 2015 at 20:10
Mossy1985
That would make more sense as it agrees with servicebox
Posted 20th Mar 2015 at 20:16
6waysforward
Number 7 the oil pressure sensor. Can I branch off that for a oil pressure gauge?
Posted 20th Mar 2015 at 23:25
jeffers Forum Admin
Yep that's exactly what I've done! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 21st Mar 2015 at 01:15
demondriverdan
Do you happen to have a guide / some pictures on what to do? Would be good to have an oil pressure sensor in the race car.
Rallye Race Car
Posted 21st Mar 2015 at 09:12
jeffers Forum Admin
Il get some pictures later or tomorrow dan no problem! Thumbs up
Posted 21st Mar 2015 at 09:31
jeffers Forum Admin
Dan I fitted one of these with the low pressure switch in the end and the sender for the pressure gauge in the side. You can buy just the adapter to fit the low pressure switch and sender straight into the block but I found I couldn't get enough room to fit the sender in the side due to the angle of the adapter when it was tightened up, il get a picture of the setup tomorrow if I can!
http://www.demon-tweeks.co.uk/motorsport/gauge-pipes-adaptors/lma-oil-pressure-remote-t-piece
Posted 21st Mar 2015 at 19:22
