Author Subject: What is the benefits of circuit breaker over fuses ?
oldbrownshoe
I see that it has button, and it's expensive, and used in jet fighters and race cars,
if money isn't an object what good it for in an ordinary car ?
reliability ?
http://www.prowireusa.com/p-881-40-amp-breaker-switch.aspx
55$
French military victories?
Did you mean French military defeats?
Posted 14th Jan 2015 at 21:52
mounting purpose, tidiness, voltage differences... Unsure
Posted 15th Jan 2015 at 12:02
Good conversation peice for the mrs over a meal also.
  • Posted 15th Jan 2015 at 12:25
    oldbrownshoe
    dangti6 wrote:
    Good conversation piece for the mrs over a meal also.
    but what if (in the rare case) yours mrs isn't a guy ??
    Posted 15th Jan 2015 at 12:41
    What if she's called Olivia?
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 15th Jan 2015 at 13:15
    ian7675
    Techno Viking
    I don't think Olivia would be much cop when it comes to conversation.
    Less than 24 hours to go!
    Posted 15th Jan 2015 at 13:37
    Actions speak louder than words
    Posted 15th Jan 2015 at 13:57
    oldbrownshoe
    With a real woman the conversation could be worse.
    Posted 15th Jan 2015 at 13:58
    craig903
    With a real women the amount off moning that would follow after mentioning this over a meal, it just isn't worth it.
    208 GTI Owner
    Posted 15th Jan 2015 at 14:54
    oldbrownshoe
    I'm not speaking with her.
    Posted 17th Jan 2015 at 13:10
    RetroPug
    You can turn a circuit breaker back on instead of replacing it.
    Posted 17th Jan 2015 at 09:39
    oldbrownshoe
    Yes, you right but, it cost like 20-60$
    and new fuse cost nothing & weight nothing.
    Posted 17th Jan 2015 at 10:31
    ian7675
    Techno Viking
    I imagine in a race/rally car the last thing you would want to do is fumble around changing fuses when you could just flick the switch. I can't see a benefit in an everyday road car really.
    Posted 17th Jan 2015 at 11:00
    demondriverdan
    This is the main benefit really. I'm going to fit some to my race car when I eventually get the wiring sorted. If you've got a wiring fault somewhere and it keeps popping the breaker out, fairly easy to push it back in. Less so with a fuse.
    That being said, the ones I'm planning on getting are no where near $50!
    Rallye Race Car
    Posted 17th Jan 2015 at 11:37
    oldbrownshoe
    Well maybe it is wiser can replace only the hungry power consumer,
    like the fans, aircon, front wiper, there is no more than 4-5,
    i wish i could take off the water pump and use electric one instead,
    it would be more reliable and eliminate another parasitic engine power consumer.
    could you give a link for cheap circuit breaker store ?
    if you working on loom what you think about using Deutsch DTM connectors and motorsport looming ?
    Posted 17th Jan 2015 at 13:31
    Twangy
    would not pay that price for one , I use ETA resettable fuses in my car for most thing ,wich are resettable and lightweight and are blade type fitting ,as seen under relays on passenger side ,,far cheaper ,, job done
    Twangy has attached the following image:
    wayne mcardle
    Posted 17th Jan 2015 at 13:34
    oldbrownshoe
    10 pound for ETA fuse don't seem cheap to me.
    Posted 17th Jan 2015 at 13:36
    Twangy
    lot cheaper than ones you were looking at , little tip some wagon tractor unit use and are fitted with ETA fuses so worth checking with wagon breakers
    wayne mcardle
    Posted 17th Jan 2015 at 13:39
    oldbrownshoe
    That's jimmyhackers turf.
    Posted 17th Jan 2015 at 13:44
    cully
    Posted 17th Jan 2015 at 14:01
    Twangy
    I use the ETA series 1170 , as shown on above link
    wayne mcardle
    Posted 17th Jan 2015 at 14:09
    oldbrownshoe
    Me like shiny one.
    9.5$
    GBP 2.19
    this look very usefull
    "10 Way Blade Fuse Box Positive Bus in 12v LED WARNING Kit Car Boat Marine Rally"
    Posted 17th Jan 2015 at 20:57
    RetroPug
    Precisely, so unless you specifically need that function it isn't worth bothering.
    Posted 18th Jan 2015 at 09:47
    oldbrownshoe
    I NEED IT TO BE RELIABLE TO WITHSTAND HEAT, HUMIDITY AND VIBRATIONS.
    Posted 18th Jan 2015 at 18:09
