displaying posts 1 to 25 of 67
Pages (3): [1] 2 3
Author Subject: Red Rallye Resto
Eddleston
Might as well get this into a project, turned out to be taking 2months longer that I planned.
So this is when I took it off dad's hands
Then as you know the engine died
So then I attempted to get it out
Hub nuts:
Everything was a pain, until one magical day
This is now waiting
Wanted to check gearbox was OK, popped it apart and it's fine.
Couldn't get back any closer than this
So pulled it up for another look. Unfortunately one of the bearings decided it was off on an adventure then. So that's that over. Gearbox will be another day.
Posted 1st Oct 2014 at 16:06
Eddleston
Engine bay:
Now after giving it some attention I have a question, how do you get the corners cleaned up?
Like in this pic
The corners are pretty horrible on lots of other places too
Posted 1st Oct 2014 at 16:33
Ben_W
Formerly gpm
I'll be watching this. Exactly what I intended to do with mine. Just need to figure out how to remove the engine
Posted 1st Oct 2014 at 16:15
Eddleston
It's a pain in the arse but my only available advice is to take the front bumper/lights off first, SO MUCH SPACE! wish I'd managed it before the engine came out.
Posted 1st Oct 2014 at 16:18
Eddleston
And areas like this. I'm trying deox gel but not impressed thus far.
I can't get any of my drill attachments in around the bent parts. No
Posted 1st Oct 2014 at 16:35
mik
I had this - get a Dremel with the small stainless brushes. They don't last too long (last almost no time if you wind the Dremel up to 30,000 RPM!) and are expensive, but you can get in loads more tight spaces. The round sandpaper looking thing for the Dremel also works well.
Deox gel works well if you degrease the area thoroughly first, get as much rust off as you can with chisel/drill/Dremel etc, and lay the Deox Gel on thick. Then cover it with cling film and leave overnight. Took me a bit of working out, but found this was the bast way. And you may need a repeat application.
Cherry Rallye SOLD
Posted 1st Oct 2014 at 19:17
RetroPug
Certainly with the Deox-C solution it worked way better once it had already been sanded down and all the paint had been removed I found. Heating the solution or making it with very hot water also made it far more rapid, although heating the gel in situ might be a bit more tricky.
Well done for really going to town on restoring this though!
PS. I think your hub nuts were a bit overtight. Laugh my ass off
Posted 1st Oct 2014 at 19:21
chiefton
Ah local man nice to see Thumbs up im near ockley
check out my project thread,I usd lots and lots of different wire wheel attachments via a drill worked a treat!!
Il be watching this one!!!
cherry rallye daily (the money pit)
unless its actually crusty I really wouldn't bother taking it back to bare metal, just key the paint and bash the primer over the lot.
Posted 1st Oct 2014 at 19:31
Eddleston
Huzzaaah!
Turns out the only thing I can get to shift the deox gel in places the drill bits won't go is uncomfortably hot soapy water and a scrubby pad. SO pleased that worked!
So, finish up the lower cross member and it's game time! Big grin
Posted 3rd Oct 2014 at 14:29
chiefton
It takes along time I did all of mine outside too,but the end result is very satisfying!!!
Just try not to scratch the fresh paint when you stick the old engine in lol!!!
Posted 3rd Oct 2014 at 14:57
Eddleston
It did take a while yeah.
And I'll have some extra eyes and hands around when it does go in, just to be on the safer side.
Posted 3rd Oct 2014 at 18:49
Eddleston
So this the bearing that left just the race behind. Will be getting something from Peugeot soon to replace it.
Now here's the outcome from a hot soapy scrubbing pad
Then made the whole cross piece shiny, was a bit 'orrible
took care of a few spots which were trying to break out
Then RedOxided the whole bastid lot
Posted 3rd Oct 2014 at 18:56
Eddleston
Also started on a couple brackets.
This was a proper mess so took it all back to metal and it was OK.
Wondering if this should go red too even though it will be barely visible
and this will probably go red as well. Even though it'll also be barely visible.
Posted 3rd Oct 2014 at 19:11
Eddleston
I saw this on FB the other day.
Looks lovely and I now want a lovely shiny new heat thing. Where can I get one? The blue writing on it just makes it look more professional I think.
Posted 3rd Oct 2014 at 19:02
Looks like somebody's re covered the standard heat shield, if not they've done a good job making it.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Oct 2014 at 19:05
Eddleston
And these things are literally incredible!
£1.50 before trade card! Shock Yes
rallyestyle
Looking good Thumbs up
Give it a year or so and i will be finding a nice place to do this to my Rallye Yes
Just Drive It
Posted 3rd Oct 2014 at 21:23
pug_306
I recognise the new engine :-) i thought you would of had it in and running by now :-) Looking good though :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 3rd Oct 2014 at 22:17
Eddleston
I thought it would be running by now too lol. As is the way though, everything that can cause a problem does do.
Posted 3rd Oct 2014 at 22:20
Eddleston
The main problem in my life right now is doing this on the drive, fcuking rain!
But it's starting to look nice in the bay
Just the paint code issues to sort out.
Posted 10th Oct 2014 at 12:49
demondriverdan
Interesting choice of white for the bay! How are you painting it, rattle cans?
Rallye Race Car
Posted 10th Oct 2014 at 14:47
chiefton
Cheery red code is p3kb I had my bumper done recently. I did mine outside in between showers lol wrong time of year lol
Posted 10th Oct 2014 at 15:02
Eddleston
Slowly but surely!
Posted 15th Oct 2014 at 16:58
Eddleston
Phone makes it look much more pink than it actually is
Pages (3): [1] 2 3
