Question...
The more research I do, the more i get confused as to the general consensus on this...
So i picked up 2 Sparco buckets for a reasonable amount of money recently, they're great but they arent FIA approved race seats, and therefore dont have the hole in the base for a 5th buckle...
And so to my dilemma...i've read the following recently:
1) Anything less than 5 points are dangerous due to 'submarining' (ie. the process of bending like a banana and sliding out under the bottom of the harness belt)
2) You shouldnt run harnesses without a cage as the harnesses keep you rigid in the seat and should you roll over your head becomes the bit the roof will collapse on and you cant get out of the way...
So right now I have concluded i'm better off running standard seat belts with the buckets until i can afford FIA seats, a cage and harnesses, does that sound about right/logical? (I guess thats no different to just going on a trackday with normal seats/belts as most people do?!)
Chr1sch
