displaying posts 101 to 125 of 135
Pages (6): first .. 4 [5] 6
Author Subject: Overheating
Chr1sch
Post #101
Anyone?
Posted 22nd Sep 2014 at 10:53
demondriverdan
Post #102
£15 posted?
Rallye Race Car
Posted 22nd Sep 2014 at 11:07
Chr1sch
Post #103
Hi Dan,
A guy locally has just offered me one so i'm going to give that a go first as he's litterally 5 mins away (its a Bitron identical to mine so less risky), if thats no good i'll certainly come back to you asap
Thanks again
Posted 22nd Sep 2014 at 11:26
Chr1sch
Post #104
Cully/Welshpug, can either of you she's light on this? If dans will work I'll buy this bloke with the exact one is messing me around something chronic and I need it ASAP!
Posted 23rd Sep 2014 at 20:18
Post #105
Only ever seen the bitron unit one a 6 ?
Posted 23rd Sep 2014 at 20:47
Chr1sch
Post #106
That's what I thought, all very confusing!
Posted 23rd Sep 2014 at 21:55
cully
Post #107
im guessing if i said it would work
but as my pm peugeot wouldnt change the spec of the box except for the temp ranges
do you know of anyone local to you with a 6 you could try their box?
think the dervs had the same box but maybe a different temp range NOT THE HDI's as they are ECU controlled
Posted 24th Sep 2014 at 12:36
Chr1sch
Post #108
Thanks Cully
So Dan is sending me his as its worth a try...the local one turned up today and its from a bloody 206, looks identical (Says bitron ppe gf10 on it) but the the molded lip is on the opposite side to the 306 one. Im assuming its not a good idea to cut the lip off and try it?
I've also been reading this thread: http://www.306gti6.com/forum/showthread.php?id=111406&page=2
is there any way if I have both fans spinning on low speed when bridging the relay that i could have a dodgy earth and they both still work? I'm assuming not...
I'll try Dan's box tomorrow when it arrives (thanks Dan) but i fear the worst and im running out of time/options before the track day :s
Posted 25th Sep 2014 at 13:11
demondriverdan
Post #109
Posted about 2 hours ago as special delivery so hopefully it will fix it! Smile
Rallye Race Car
Posted 25th Sep 2014 at 14:01
Chr1sch
Post #110
FFS I could cry, fitted dans bitron and no difference, i'm utterly lost now, I've done everything people suggested!?
To recap I've done all of the following/these all happen:
1) remove brown plug and only drivers side fan spins at high speed
2) looking at the car head on if I bridge pins 3 and 5 of the right hand upper relay (green 4 pin) both fans spin at low speed
3) replaced black 5 pin relay
4) swapped the 2 green relays over and same scenario as above happens (assume this means both are ok)
5) replaced bitron
6) checked look connection in bottom right of fan housing
7) checked all fuses inside car
So based on above what on earth can be wrong with it?!
Could both still spin up when I bridge the green relay if there was a dodgy earth?
Does anything look wrong here? (Is this the earth? Fuse 8 is missing?)
Anything would be massively appreciated :-(
Posted 26th Sep 2014 at 15:36
cully
Post #111
hmmmm well erm thinking time again
is dan's bitron known to be working?
did you check the earth points under the battery tray on the chassis leg?
Posted 26th Sep 2014 at 15:57
Chr1sch
Post #112
Hi Cully, thanks i've been looking for that lol!
To top it all off i've just locked the car in the garage, with the garage keys in...
Dan's was off a working car so not 100% guaranteed but pretty unlucky!
Posted 26th Sep 2014 at 16:05
cully
Post #113
the earths are just in front the battery on the chassis leg
your fuse box has an extra fuse fitted compared to mine but mine might be wrong who knows
you could try doing the A/C switch mod to use the ac button as the fan switch see if that forces the relays to power the fans
unplug A/C compressor white plug
unplug A/C pressure switch
bridge selected pins on the plug for the pressure switch
Posted 26th Sep 2014 at 16:14
Chr1sch
Post #114
You sir are a true gent thank you!
Posted 26th Sep 2014 at 16:56
demondriverdan
Post #115
Fans worked on the car, used to sit at a steady 90 degrees in traffic. I think he did the fan mod as well though.
Rallye Race Car
Posted 26th Sep 2014 at 17:37
cully
Post #116
i have another drawing for you
this drawing is the cable layout with wire numbers
i sugest checking the two aditional loom plugs on the n/s chassis leg at low level these are the engine loom plugs but some fan controls and power run through them
Posted 26th Sep 2014 at 19:36
Chr1sch
Post #117
Ah great thanks :-)
Posted 26th Sep 2014 at 21:14
Chr1sch
Post #118
Ok so I've done the ac switch mod and only the drivers side comes on!?
Posted 27th Sep 2014 at 18:41
Chr1sch
Post #119
Can one fan work and still have a dud earth?
Posted 27th Sep 2014 at 19:21
cully
Post #120
please recheck fuse F2
even pull it out and replace it, check the ends arnt burned
use a multi metre to check it dont rely on a visual check as they can look good and still be bad
you wont have a dead earth as you can get both fans spinning via linking 3-5 on the relay base
both fans use the same earth point
Posted 27th Sep 2014 at 20:13
Chr1sch
Post #121
Thanks cully will do , for the avoidance of doubt:
1) shall I replace both green relays?
2) which is fuse f2? (I've already multimetred all of them but will replace as described...)
Posted 27th Sep 2014 at 23:52
Post #122
Check the loom plugs at the front of the car to the right of the rad
Posted 28th Sep 2014 at 00:43
Chr1sch
Post #123
Yep done that already bbb like new!
Posted 28th Sep 2014 at 07:43
cully
Post #124
F2 -F3 are the two 40 amp fuses side by side on there own in the engine bay fuse box
Posted 28th Sep 2014 at 09:48
Chr1sch
Post #125
Awesome thanks will check now :-)
Posted 28th Sep 2014 at 09:52
