displaying posts 126 to 135 of 135
Pages (6): first .. 4 5 [6]
Author Subject: Overheating
Chr1sch
Post #126
Fuses (assuming you're referring to the bottom 2 in your pic) are both fine - checked with multimeter
Both fans spin at low speed if I bridge right hand green relay...
Posted 28th Sep 2014 at 10:43
Chr1sch
Post #127
The only things I haven't replaced (assuming dans bitron is ok) are the green relays!
Could a faulty green one (or even 2 faulty green ones) cause this scenario, if we've discounted black relay, wiring, plugs, earths and know by bridging both fans spin at low speed and ac over ride thing only spins drivers at high speed...
I haven't a friggin clue!
Posted 28th Sep 2014 at 13:34
Chr1sch
Post #128
Bump
Posted 28th Sep 2014 at 14:54
Chr1sch
Post #129
well the green relays are virtually impossible to match (i.e. 12v/25a) only peugeot seem to have the right one and they're £17 each!
I guess i'll replace both just to ensure its not them causing the issue, unless someone can tell me categorically if they could even cause the symptoms described?
Posted 29th Sep 2014 at 11:07
cully
Post #130
to get slow speed one green relay needs to switch
to get fast speed all three relays need to switch
and yes a faulty green relay could cause this
but you said you swapped relays around
you could pinch the green relays in the cabin fuse board as they do the wipers i believe
Posted 29th Sep 2014 at 18:29
Post #131
you need to confirm the signal is getting to the relays.
Posted 29th Sep 2014 at 18:45
Chr1sch
Post #132
That's the signal from the bitron right? How could I check that? Multimeter job?
Posted 29th Sep 2014 at 20:24
pauldoubleyou
Post #133
Surely just pull two relays from the scrappers?
Paul
Hiding with Pride
Posted 29th Sep 2014 at 20:37
Chr1sch
Post #134
Christ I haven't been to a scrap yard for 12 years, wouldn't even know where one is! Off to find yellow pages...
Posted 29th Sep 2014 at 22:17
Chr1sch
Post #135
Morning gents
So this wasn't ever actually resolved and given the winter hibernation I'm keen to get it fixed once and for all...
As I plan to remove all the aircon parts etc, could I afford to only run the one fan as per a Rallye or can I hardwired the second fan into the first and just control both via the dash switch?
Posted 1st Dec 2014 at 08:07
