work out which relay is 1508,
remove the relay
and bridge pins 3-5 in the socket without the relay plugged in but leave all the other relays in
you should get slow speed with the ign off
| Author | Subject: Overheating |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
Post #76
to prove both fans workwork out which relay is 1508, remove the relay and bridge pins 3-5 in the socket without the relay plugged in but leave all the other relays in you should get slow speed with the ign off |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Post #77
Ok so the saga continues!Bridged the one relay (I thought whats 1508) only one fan spun, bridged the other one (clearly 1508!!) and BOTH fans spun! So at least i know i have working fans and wiring... Checklist: 1) Working fans 2) New black 5 pin relay 3) Other 2 relays must work as when i switch them over the one fan still operates - although this isnt a 100% guarantee? So in conclusion, if the bridging cully advised above works, does that conclude it must be the bitron thing? |
Chr1sch
Post #79
You sir are a legend!Thanks I'll check that next... |
Chr1sch
Post #80
Interestingly a/c is dead too... |
cully
Post #81
most AC on 306's is dead due to loss of pressure from coroded lower condensor pipesAC will fail safe if there is an issue with it i wouldnt think its related more of a second problem....can of worms |
Chr1sch
Post #82
Thanks again cully, Would this be the same?! Look at this on eBay: http://pages.ebay.com/link/?nav=item.view&alt=web&id=300635839683 CITROEN SYNERGIE XANTIA PEUGEOT RADIATOR FAN ECU 9633609680 CCTuP5/BVA2 BITRON Cheers Chris |
cully
Post #83
honest answer is i dont know you need to check the part numbers |
Post #84
1338 A1 is the unit listed for a git6, temps of 96/118 listed for it, it is listed for an XU10J2 806, so it will work, a TD one is listed at 90/101 for early models or straight 118 for later ones.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cully
Post #85
good man i trawled service box and couldn't find the bloody thing ![]() |
Chr1sch
Post #86
Thanks guys, sounds like I may be better off looking for the exact one rather than this one then? (Appreciate you said it would work, not clear if that was as a compromise or equally well as the actual one for a gti6?) |
Chr1sch
Post #87
Welshpug do you have the part number for 1138 a1? |
demondriverdan
Post #88
Aha, now I know what you mean by the bitron unit. Will see if my Dad can take if off the shell for you.________________________________________ Rallye Race Car |
Post #89
Chr1sch wrote: Welshpug do you have the part number for 1138 a1? errrrrrrrrr..... ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Chr1sch
Post #90
I get what you're saying Welshpug but most seen to have a longer number like this :PEUGEOT 206 406 CITROEN COOLING FAN RELAY . MANUFACTURED BY BITRON . PART NUMBER 9633609780 . COLOUR BLACK . ITEM IS USED & IN GOOD WORKING ORDER |
Chr1sch
Post #91
demondriverdan wrote: Aha, now I know what you mean by the bitron unit. Will see if my Dad can take if off the shell for you. Thanks! Only 2x10mm bolts! |
demondriverdan
Post #92
He's going to check tomorrow, will let you know ![]() ________________________________________ Rallye Race Car |
cully
Post #93
the longer numbers are normaly the manufacturers numberspeugeot use a 6 digit letter system ****.** |
Chr1sch
Post #94
Oh thanks, every day is a school day lol |
demondriverdan
Post #95
Here's the box I've got on the car. Any good?![]() ![]() ________________________________________ Rallye Race Car |
Chr1sch
Post #96
Cully/Welshpug can you advise? Mine says bitron on it rather than g Cartier? If this has come off another gti6 is it going to be the same? Cheers guys!!! Chris |
Chr1sch
Post #97
Incidentally I've looked at the connectors on my bitron one and they were all fine bar one which was totally covered in white crusty stuff. I've cleaned it and tried unplugging the brown plug but no avail...I have also bridged the one relay to check and both fans definitely spin up, there's nothing else bar the bitron I should now be suspecting is there? If someone can confirm if that box above is ok I'll buy it ASAP for sure :-) |
Chr1sch
demondriverdan
Post #99
The lugs line up on the two boxes but that could just be the design is the same. Yours looks like a Ph3, which is what this came off.________________________________________ Rallye Race Car |
Chr1sch
Post #100
I think mine is a 2.5, cully/welsh either of you have any idea if it would be a feasible replacement?Dan, how much do you want for it posted? (The one above on eBay was £14 as a point of ref but they do vary..) Cheers Chris |
