displaying posts 126 to 150 of 217
Pages (9): first .. 5 [6] 7 .. last
Author Subject: 2014 High Boost project
pete-gti
Post #126
buzzbrightyear wrote:
Sx150? Have they updated the oil now, in sure it used to be sx100
yea updated Smile
was happy with that price every where else was between 120-130 with postage
Posted 8th Jan 2015 at 13:49
Post #127
yea updated Smile
I knew there was issues with the previous fluid, hopefully it won't bubble and froth up anymore, funny how everyone concerned swears blind it's fine but yet there's threads concerning the issue All over net and then they suddenly update it.
There all full of s**t who sell the things
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 8th Jan 2015 at 18:42
pete-gti
Post #128
i never used the old one even when i went low boost so never came across that problem , never heard of the old one doing that common problem?
Posted 8th Jan 2015 at 19:57
pete-gti
Post #129
Hoping tomorrow be fire up day :-). All that's left is to wire up the pump :-) spent today getting the fuel lines tidy and fitting last couple of connections
Hoses run along where the standard lines use to be
Posted 9th Jan 2015 at 16:44
pugheaven
Post #130
What the hell have you done to that poor old rear seat floor Sad
Posted 9th Jan 2015 at 17:07
pete-gti
Post #131
What you mean lol
Where the fuel lines go threw? ,
Posted 9th Jan 2015 at 17:12
pugheaven
Post #132
Where you have cut away to allow the hoses to come out
Posted 9th Jan 2015 at 17:09
pete-gti
Post #133
:-) got nice little idea for that , will look smart once it done ,
Posted 9th Jan 2015 at 17:15
pugheaven
Post #134
Good good, bit late but you could have just put two grommets but have them so they were oval and had the hoses going through them
Posted 9th Jan 2015 at 17:17
pete-gti
Post #135
Only two holes ,
Going to protect to it all :-). Fill holes in so it don't rub
Still need to bolt the roll cage leg ,
Posted 9th Jan 2015 at 17:37
pugheaven
Post #136
Hope the wiring hasn't been crushed!
What is that in between the 2 unions?
Posted 9th Jan 2015 at 20:19
pete-gti
Post #137
There's like a inch gap between the plate and wiring:-) , wiring can be easy moved out way and I have few square plates made up to fill the gap
Its a easy release 6AN JIC AN-06) Quick Connect 5/16" Female Fuel Line adapter
Posted 9th Jan 2015 at 23:05
pete-gti
Post #138
ClappingClapping
Well after few little teething problems she is now up and running :-) idles and revs lovely , after 10 minutes had to stop as oil cooler rad is p**sing oil out , has a crack near the connection joint Sad
So ordered up a new cooler and new braided oil lines , so going scrap the old setup as it was just rubber hoses and they didn't look great seen better days , so should be here Monday :-) get them fitted and should be able to test drive it round the yard :-)
Couldn't get a video as oil was p**sing out will get one once its sorted
Cheers for everyone's help last week be very much appreciated :-)
Posted 17th Jan 2015 at 18:32
Post #139
And sort out your harness mounting points, they'll do your collar bones at that angle Thumbs up
Posted 17th Jan 2015 at 18:56
Post #140
I have a harness bar that mounts to the rear seatbelt mounting points if you need it bud ?
Sure there is a pic on here of it ?
Posted 17th Jan 2015 at 19:00
pete-gti
Post #141
been after one of those bars for ages will pm you Smile
Posted 17th Jan 2015 at 19:21
gilesy
Post #142
Watch out for chafing where the pipes go through
Posted 17th Jan 2015 at 19:24
Post #143
Yes you don't want them earthing!
Posted 17th Jan 2015 at 19:26
Post #144
arent those swirl pots meant to be under the boot floor the other way up?
Posted 17th Jan 2015 at 19:34
Post #145
Dont know exaclty what it is but it's not a rich w built one of that's what your thinking.
Posted 17th Jan 2015 at 19:40
fatlapit
Post #146
Posted 17th Jan 2015 at 20:18
pete-gti
Post #147
Yea I'm filing holes in with rubber sealant stuffSmile so the hoses want rub
Seen a few with this setup in the car , just didn't like the fact of it all under the car , plus makes it a lot Easyer to work on Smile
Posted 17th Jan 2015 at 21:42
rallyeash
Post #148
I'd personally not do that and get proper bulkhead fittings
309 3dr K20 Type R
Posted 17th Jan 2015 at 22:29
Post #149
I agree, if an accident occurs there's a chance them pipes are going to get sliced in half and fuels going to go everywhere with the pressure its under
Posted 17th Jan 2015 at 22:43
fatlapit
Post #150
u still got an inertia switch??
Posted 17th Jan 2015 at 22:48
