displaying posts 101 to 125 of 217
Pages (9): first .. 4 [5] 6 .. last
Author Subject: 2014 High Boost project
fatlapit
Post #101
nah. just initially i had cooling problems as my intercooler is 5" thick so there wasnt enough airflow through the rad so i had to take my grille of.
Posted 27th Dec 2014 at 19:05
fatlapit
Post #102
pugheaven
Post #103
If his intercooler is the same as my old one which was a pro alloy one it won't suffer from air flow!
Pro alloy told me that their interoolers are more than twice as efficient as a eBay cheap item
Posted 27th Dec 2014 at 20:13
fatlapit
Post #104
suppose being sc ure under bonnet temps are less also im not suprised they are twice as efficient as they are half as thick lol.
Posted 27th Dec 2014 at 20:17
pugheaven
Post #105
After speaking to them at pro alloy I got told that I would only need a 75mm thick pro alloy cooler but if I was using a eBay item I would need to be running one twice as thick to achieve the same results!
Cheap mass produced eBay items will restrict air flow and add unnecessary weight.
They only use a 75mm cooler on 600hp cosworths and only use 100mm thibck ones on 1000hp supras etc
Posted 27th Dec 2014 at 21:03
fatlapit
Post #106
cores arent too disimilar tbh but my tanks have been cut off and put diverter flaps in. tbh if your spending money on stuff go to spec r.
Posted 27th Dec 2014 at 21:10
fatlapit
Post #107
also the inlet n outlet angles have been changed
Posted 27th Dec 2014 at 21:17
pete-gti
Post #108
yea im using the pro alloy intercooler
Posted 28th Dec 2014 at 11:27
pete-gti
Post #109
Had a little play on car today , got bit carried away and replaced to little screws that hold the disks onto the hub lol , as most of mine are broke , so I drilled and taped them :-)
Fitted my oil coiler on today didn't have much option where to put it so mounted it to front of intercooler , bumper just fits on witch was a bit of luck :-)
And fitted oil catch tank :-)
Now for a few beers before the party tonight lol. Hope you all have a nice new year :-)
Posted 31st Dec 2014 at 14:45
Post #110
At you running standard rad, Did you have to do anything to get the 2.5inch pipes to fit through from the charger on the d/s?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 31st Dec 2014 at 14:47
pete-gti
Post #111
Nissan rad , no but its a bloody tight fit wouldn't fancy taking it all back out lol
Posted 31st Dec 2014 at 14:51
Post #112
I bet it is i had
A quick test try and couldn't get it through but it was only just, I never forced it but I suppose it could go if rad was 1-2mm further to the right
Posted 31st Dec 2014 at 15:20
pete-gti
Post #113
Yea I had to force mine lucky didn't brake nothing that's the kind of things that would happen to me
Posted 31st Dec 2014 at 15:24
pugheaven
Post #114
Is the pipework not the stuff mechanical repairs supplied with the cooler? If so it's not 2.5" and only 2" for the bit that goes along side the rad
Posted 31st Dec 2014 at 16:02
pete-gti
Post #115
i changed it to 2.5 was a right ball ache fabin it up , it want be coming back out easy lol
Posted 31st Dec 2014 at 16:07
pete-gti
Post #116
Front end starting to look like a car now , headlights back in , wired up fans , put sc air scoop back on , just waiting for my fuel lines to turn up , just a matter of wiring the pump up etc ,sort oil catch tank out, need to order some rotrex oil can't believe how much that stuff is for such a small amount crazy lol, and need to buy a breather for the icv
Posted 2nd Jan 2015 at 17:24
pete-gti
Post #117
Had a good day on the girl , pretty much there now , just need to run new fuel lines and wire up the Bosch pump and bobs your uncle :-) :-)
Fitted new alarm box today lol , got a 306 with a working alarm makes a change haha
Engine bay pretty much done , just need to get strut brace re sprayed , run fuel lines and wire pump :-)
Connected battery , alarm works , lights etc all work , so far so good
Posted 5th Jan 2015 at 16:44
rallyestyle
Post #118
Engine is looking very nice Yes Done a great job there Pete Thumbs up
Good work keeping the thread going too, will be useful to me in the future Smile
Just Drive It
Posted 5th Jan 2015 at 18:38
Post #119
Can't help thinking that oil cooler should be somewhere different. It's really going to heat up the intercooler being sat there... Otherwise that's proper tidy mate!
Just for information if you want the best coolers use PWR cores Smile
Posted 5th Jan 2015 at 23:14
pugheaven
Post #120
Is the throttle cable not ment to go in the rubber bung on the bracket of the inlet??
Posted 6th Jan 2015 at 09:19
pete-gti
Post #121
How did i miss that was ment to change it round Cool lol totally forgot
Thing is with the oil cooler is routing it putting it some where else , see how I get on :-) I'm not going be using a grill so hoping there still be enough flow , but if it ends up giving me problems will have to change it Smile
Posted 6th Jan 2015 at 11:02
pete-gti
Post #122
Got some nice halfords oil , should keep the high boost going lol , can't wait to drain this stuff out and get some royal purple in there :-)
Also ran my fuel lines today :-). , just need to wire up pump etc now and waiting for my rotrex oil to arrive ,
Not long noww :-) :-) :-)
This was how it looked but ive changed the routing now will get some pictures this week Smile
Posted 6th Jan 2015 at 17:20
pete-gti
Post #123
Rotrex oil turned up today well impressed only ordered it yesterday morning ,payed £106 and that's with postage
Bought it from http://www.tegiwaimports.com
Posted 7th Jan 2015 at 18:59
Post #124
Sx150? Have they updated the oil now, in sure it used to be sx100
Posted 7th Jan 2015 at 23:41
fatlapit
Post #125
http://www.306gti6.com/forum/showthread.php?id=156995
post 8
Posted 8th Jan 2015 at 06:54
