displaying posts 76 to 100 of 217
Pages (9): first .. 3 [4] 5 .. last
Author Subject: 2014 High Boost project
pete-gti
Post #76
sandwich plate sits between the filter and heat exchanger. The extension bolt just goes through the middle of the sandwich plate and allows the filter to then sit on the end, securing the plate in place and allowing the oil through it.
Posted 8th Dec 2014 at 15:01
pete-gti
Post #77
Rest of my spoox hoses turned up today , so that's all water hoses , oil breather pipes will be replaced , hit the bank account a bit lol but had to be done other wise it will let the engine bay down big time lol :-)
Made up a peace of the oil breather pipework looking good :-)
Fitted new aux belt on aswell tommorow engine going in :-)
Posted 8th Dec 2014 at 17:14
jimmyrallye
Post #78
Looking good and comeing all together nicely ... I dread to think how much money this is costing you
Posted 8th Dec 2014 at 21:23
pete-gti
Post #79
ENGINE IS IN :-) :-) :-) :-) :-) :-)
Was good dry day so thought best get my ass in gear and get the baby fitted , all went well , also started to fit the new hoses , bottom rad hose and oil breather , then before I knew it it was getting dark , so just need to add all the other stuff to the engine and get my drive shafts ordered up :-)
Posted 9th Dec 2014 at 16:42
pete-gti
Post #80
dont ask lol
Posted 12th Dec 2014 at 04:12
pete-gti
Post #81
My new drive shafts turned up today from j and r come with 2 year warranty , will let you no if I have any problems with them as never bought drive shafts from them before
My jobs now are :
: run fuel lines to fuel rail
:fit Spark Plugs BKR8EIX
: fit drive shafts
: assemble front end
And she should be pretty much there :-) might be running by Xmas
Posted 18th Dec 2014 at 20:43
fatlapit
Post #82
whats special about the shafts??
Posted 18th Dec 2014 at 22:32
pugheaven
Post #83
They look thinner in diameter than oem ones so they are probably solid and not hollow
Posted 18th Dec 2014 at 22:39
jmh306
Post #84
I have J and R drive shafts on my Transit Connect for the last 2 years. The boots split on them quite easy. But they do the job.
FB: South Downs French Car Club
Diablo 6 2001 low boost
Diablo 6 2000 100% standard working air con
Vw Caddy tdi work van
Posted 19th Dec 2014 at 13:32
pete-gti
Post #85
Was speaking to someone over on pug306 they had j and r drive shafts been on about year had no problems so far
Posted 20th Dec 2014 at 12:03
pete-gti
Post #86
Right boys and girls little more progress :-). , fitted drive shafts and started to put front end back together , and managed to get loom back in , my NGK Iridium Spark Plugs BKR8EIX 2668 Heat Range 8 turned up today , when I first run engine in is it best to use standard plugs?
I need to order up some royal purple oil whitch is very costly some proberly be after Xmas now
Fitted slam panel on looks thousand time better powder coated :-)
Goodbye reducer ring :-) :-)
These fittings make things so mucher Easyer :-)
Hoping to get a good day on it tommorow get few more bits fitted , need to sort out oil cooler rad and the supercharger oil rad :-)
Posted 22nd Dec 2014 at 18:09
fatlapit
Post #87
run the plugs u intend to run. put s**t oil in it for now then when its time to do serious dyno time put the RP Oil in. remember to flush the oil cooler
Posted 22nd Dec 2014 at 18:20
rallyestyle
Post #88
Can't wait to one day pop my reducer ring Thumbs up
What are you doing with the gearbox?
Just Drive It
Posted 22nd Dec 2014 at 19:43
pugheaven
Post #89
Don't even ask about the gearbox lol
Posted 22nd Dec 2014 at 22:27
rallyestyle
Post #90
LOL Im waiting for somebody with an upgraded gearset to actually finish their build.... Razz
Just Drive It
Posted 22nd Dec 2014 at 22:33
pete-gti
Post #91
gearbox staying standard , fitted lsd . few people have had problems with gearbox once high boost . but then theres a few witch people have has no problems, will see what happens worse happens box be coming off and be getting uprates gears Smile
Posted 23rd Dec 2014 at 09:40
rich_w
Post #92
You need to run it with standard heat grade plugs during running in - the BKR8EIX's won't get hot enough to self clean during running in, they will foul up, then your car won't start Smile
As others have said, put some cheap 10W40 in initially, we normally do about 100 miles to break in everything that's new and flush out the graphogen and other assembly compounds, then put the Royal Purple XPR 20W50 in.
After another 100 or 200 miles you should be OK to open it up - we don't run them in for more than about 300 miles in total - with the plateau honing and tolerances the engine is built to, you don't need to.
Rich Smile
Contact Details:
07732 822546
Posted 23rd Dec 2014 at 17:37
pete-gti
Post #93
Will stick standard plugs in :-) witch you gave me just found them , will get Some cheap oil then get the royal purple ordered up after Xmas , :-)
Posted 23rd Dec 2014 at 18:09
fatlapit
Post #94
i would say run a hdi box but ud need to change the clutch and i dunno if ull pull the gears. i run a atb ive no problems on track with it
Posted 23rd Dec 2014 at 18:22
fatlapit
Post #95
rich did my engine feels nice n strong my limit is set at 7200 for now but did have it at 8600 on dyno
Posted 23rd Dec 2014 at 18:24
superchargedblack1997gti6
Post #96
to be fair the gears are fine as long as you're sympathetic, just don't let it spin up in third and you should be fine. Pete I've also used these shafts and had no issues at allThumbs up
Posted 23rd Dec 2014 at 19:14
pete-gti
Post #97
Yea hopefully I want have no problems with the gears , filled box up with gear oil nothing leaked :-) so that was a bonus lol
Shame the battery tray gets hidden never to be seen again
What's peoples view on the s5 Bosch battery?
Posted 26th Dec 2014 at 16:02
pete-gti
Post #98
Had few hours today to try and get intercooler and pipework fitted , only just managed to get them threw the sides don't remember it being that tight lol , side pass deff best option didn't fancy them going underneath the car like when I first did it when low boost kept catching every bump was so worried that one day would rip the whole thing off ...
Going to try and get a good week on it next week :-) hopefully want be to far away
Posted 27th Dec 2014 at 17:36
fatlapit
Post #99
u getging rid of your grill
Posted 27th Dec 2014 at 17:58
pete-gti
Post #100
I got 2 grills in my shed , you after one?
Posted 27th Dec 2014 at 18:04
