| Author | Subject: 2014 High Boost project |
fatlapit
Post #51
i just got rid of my pump ________________________________________ |
jamiek_uk2000
Post #53
Your going high boost though which is at the top end of what people get 150% up on standard power. Does the 12 month warranty cover you blowing it to smithereens with power?________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
fatlapit
Post #54
its torque that kills clutches and standing starts. being supercharged clùtch should be ok as delivery of torque will be nice and linear. but with anything with cars you get wat u pay for. theres a reason why helixes are expensive.________________________________________ |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
Post #55
Standard clutch good for 400? They say . see how i get on with it i like to be different. I no couple people have uses these so far so good |
fatlapit
Post #56
tbh i know people that buy "performance" clutches n get the friction material taken off n put tractor stuff on________________________________________ |
pete-gti
Post #57
See what happens :-) , nice to try other stuff |
pete-gti
vandal.pr!
Junior User Location: Zadar, Croatia Registered: 18 May 2008 Posts: 63 Status: Offline |
Post #60
I noticed that your discks are facing the wrong way?Love the project tho. ________________________________________ Peugeot 306 s16 '97--- |
barrym
Senior User Location: Westcliff-on-sea Registered: 26 Jun 2014 Posts: 502 Status: Offline |
Post #61
vandal.pr! wrote: I noticed that your discks are facing the wrong way? Love the project tho. Not if the internal vanes are facing the right way. If they are non-directional then yes you are right ________________________________________ China D Turbo HDi daily chargerBlack Rallye occassional toy |
fatlapit
Post #62
my aps are the same but they squeek like hell________________________________________ |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
Post #63
Will that clutch fit? The release bearing is normally integral to the cover ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
pete-gti
Post #64
Yea fits , if it fails then I will change , but always open to new ideas |
pete-gti
rich_w
Post #67
Pete,What ECU and injectors are you using? If your using our latest high-boost software which uses the Siemens Deka injectors, you only need a 3 BAR FPR. Cheers Rich ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
pete-gti
Post #68
Hi rich , yea using the map and injectors that I picked up from you when I got the engine off you , sure? Thought it had to be 4 bar with high boost , will it do any harm or is it best to change back? |
Post #69
it will overfuel ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pete-gti
Post #70
Will have to source another one , pretty much had to destroy the old one would not come out easy, never mind :-) |
pete-gti
pete-gti
fatlapit
Post #73
are you not running an engine oil cooler??________________________________________ |
pete-gti
Post #74
Yea mocal one will fit it once engines in |
fatlapit
Post #75
just uve still got your heat exchanger fitted________________________________________ |
