displaying posts 51 to 75 of 537
Pages (22): first .. 2 [3] 4 .. last
Author Subject: 306 rallye track/stage project
RetroPug
Post #51
Looking forward to seeing the carbon slam panel! Most of the ones I've seen have been carbon-kevlar.
Posted 14th Aug 2014 at 19:27
Twangy
Post #52
RetroPug wrote:
Looking forward to seeing the carbon slam panel! Most of the ones I've seen have been carbon-kevlar.[/quo
te]
will be reinforcing with some carbon Kevlar ,as have some off cut but not a full piece to make in one complete peicei
wayne mcardle
Posted 14th Aug 2014 at 19:32
pugheaven
Post #53
What rad are you using?
Posted 14th Aug 2014 at 21:15
Twangy
Post #54
the rad is one of my old grp A escort cosworth ,
wayne mcardle
Posted 14th Aug 2014 at 21:32
pugheaven
Post #55
Thought it might be, I'm thinking about using the rs500 rad and intercooler on the dimma but I think the bottom pipe will be where my power steering pump is Thumbs down
How much clearance do you have from the tip of the rad to the underside of the slam panel?
Posted 14th Aug 2014 at 22:28
Twangy
Post #56
had to make up bottom hose on car to make fit ,so you should be able to get good clearance by doing same ,am going to be using other left over grp a cosworth bits on it as well ,have rear cosy 285/25mm disc and bells wich will use on front , just trying to do deal on the AP calipers
Twangy has attached the following image:
wayne mcardle
Posted 14th Aug 2014 at 21:56
pugheaven
Post #57
Have you trial fitted the bells and rotors as they look like the rotors are offset and might hit the ball joints
Posted 14th Aug 2014 at 22:01
Twangy
Post #58
not yet had chance , but if comes to worst will get new bells made up , will wait till got calipers and do the lot in one go
wayne mcardle
Posted 14th Aug 2014 at 22:11
demondriverdan
Post #59
I might be interested in a lightweight slam panel if you're selling them Smile
Rallye Race Car
Posted 14th Aug 2014 at 22:42
Twangy
Post #60
was not really planning on selling them , but will see how they turn out ,seen as will have mould
wayne mcardle
Posted 14th Aug 2014 at 22:46
Post #61
Can always be cut off, blanked and re-located.Thumbs up
Posted 15th Aug 2014 at 12:33
RetroPug
Post #62
I knew someone would. LOL
Posted 15th Aug 2014 at 15:25
jamiek_uk2000
Post #63
1. Demon driver dan
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 16th Aug 2014 at 00:40
Twangy
Post #64
little update with slow progress due to still being one legged ,
wayne mcardle
Posted 29th Sep 2014 at 15:48
Twangy
Post #65
made and fitted carbon front panel , still got to superfine and polish but will save for later date ,good weight saving
wayne mcardle
Posted 29th Sep 2014 at 15:50
Twangy
Post #66
also remove headlamps and fitted blanks ,a little bit more weight saved
wayne mcardle
Posted 29th Sep 2014 at 15:53
Twangy
Post #67
also repositioned air filter as someone on forum advised
wayne mcardle
Posted 29th Sep 2014 at 15:56
Twangy
Post #68
hopefully this week will remove bonnet and start to make fiberglass mould ,ready to make lightweight carbon bonnet
wayne mcardle
Posted 29th Sep 2014 at 15:59
Twangy
Post #69
and all fitting nicely
wayne mcardle
Posted 29th Sep 2014 at 18:29
Twangy
Post #70
im trying to get some false vinyl headlight stickers to make look authentic headlights
wayne mcardle
Posted 29th Sep 2014 at 18:33
pauldoubleyou
Post #71
A stupid question, but how much weight are you anticipating saving by drilling holes?
Paul
Hiding with Pride
Posted 29th Sep 2014 at 20:55
Twangy
Post #72
just trying to save any little bit I can , even down to replacing bolts with alloy ones were possible , every bit helps ,bumper holes will be covered with thin carbon with stick on number plate ,and once have got all weight down will turn attention to power plant
wayne mcardle
Posted 29th Sep 2014 at 21:21
Phil white
Post #73
How are you running no pas? Just disconnected pipes? Did you keep the ram? Did you cap the connections off?
I've bought a tensioner & belt to delete the pump but unsure how to run the rack effectively. Any advice appreciated..
Posted 7th Oct 2014 at 20:58
Post #74
When i was running without pas i had a short length of flexi hose made up that connected to the two holes on the rack (high pressure inlet and return), then i poured a load of fluid in until i couldnt get any more in and fitted the hose, making it a very short loop.
In hindsight i should have probably removed the ram and made a stop to limit the rack travel distance.
Posted 8th Oct 2014 at 06:48
demondriverdan
Post #75
I run mine with no fluid in the rack or ram but not sure this is a good idea! Going to remove the ram this weekend although I'm probably no going to fit a stop, barely turn the wheel enough for it to make sense.
Rallye Race Car
Posted 8th Oct 2014 at 09:12
