displaying posts 76 to 100 of 537
Pages (22): first .. 3 [4] 5 .. last
Author Subject: 306 rallye track/stage project
Twangy
Post #76
Phil white wrote:
How are you running no pas? Just disconnected pipes? Did you keep the ram? Did you cap the connections off?
I've bought a tensioner & belt to delete the pump but unsure how to run the rack effectively. Any advice appreciated..
hi phil , disconnected all pipes and turned wheel side to side to remove any remaining fluid , try and get a bit of grease in rack fitting with grease gun to stop running dry ,and just cap fitting to stop any dirt getting in rack ,I used plastic caps of hydraulic fitting , I removed ram as am only running five speed box with 4.44 cwp , as most tracks you wont need 6th gear , but you could make some rack stops so you can remove ram ,would not make small pipe and fill with fluid as will cause resistance in rack ,and end up feeling really heavy ,lhope this helps wayne
wayne mcardle
Posted 8th Oct 2014 at 09:18
Twangy
Post #77
rear screen fitted with lexan formed bonded screen , a lot lighter , and rear heavy rubber spoiler removed and mould made ready for carbon light weight one to be laid up will show photos of spoiler in next day or so
Twangy has attached the following image:
wayne mcardle
Posted 8th Dec 2014 at 10:46
Twangy
Post #78
found few more photo of car ,
wayne mcardle
Posted 12th Dec 2014 at 10:18
Twangy
Post #79
bit more carbon
wayne mcardle
Posted 12th Dec 2014 at 10:20
Twangy
Post #80
collecting fiberglass body moulds this week ,so next thing to be done on car will be carbon bonnet ,carbon rear hatch , and carbon doors , and maybe maxi / dimma kit as also have moulds .will add photo as soon as have picked up
wayne mcardle
Posted 29th Dec 2014 at 21:12
Twangy
Post #81
collected moulds yesterday so will be making panels over next few week to remove more weight from car
wayne mcardle
Posted 3rd Jan 2015 at 16:25
Twangy
Post #82
fibre glass inner and outer door mould ,will be making carbon/ Kevlar doors
wayne mcardle
Posted 3rd Jan 2015 at 16:27
Twangy
Post #83
will also making carbon fibre bonnet as have also got moulds for phase 1 and phase 3 bonnets
wayne mcardle
Posted 3rd Jan 2015 at 16:45
Twangy
Post #84
there is also rear hatch mould ,so that will also being made out of carbon Kevlar , wich is a bit of a pain as will have to remove lexan rear window wich was bonded in hatch on car now
wayne mcardle
Posted 3rd Jan 2015 at 18:58
Bazmozpug
Post #85
Is the front bumper mould a dimma type or maxi type bumper and how much to mould one for me thanks Barry
Posted 3rd Jan 2015 at 20:41
Sonnyp
Post #86
I'm after carbon fibre or fibre glass bonnet for mine where did you get the moulds or did you wake them yourself?
Posted 3rd Jan 2015 at 21:27
Twangy
Post #87
urself?
bought moulds . as it save a lot of time .
wayne mcardle
Posted 3rd Jan 2015 at 22:00
Twangy
Post #88
hi barry ,haven't really had time to have proper look as was just dumped in garden . but will have look tomorrow
wayne mcardle
Posted 3rd Jan 2015 at 22:06
Twangy
Post #89
will be making fiberglass bonnets if your after one ,also hatches and doors
wayne mcardle
Posted 7th Jan 2015 at 20:13
Twangy
Post #90
seriously thinking about wide arching car now , as have spoken to good mate of mine who was the head engineer of RED back in there hayday and cant see any problem making wide track mods ,
wayne mcardle
Posted 7th Jan 2015 at 20:59
pugheaven
Post #91
That's not a dimma/maxi mould, looks more like the "ice" wide body kit
Posted 7th Jan 2015 at 21:44
Twangy
Post #92
haven't had proper look at arch moulds to see what they are
wayne mcardle
Posted 7th Jan 2015 at 21:49
pugheaven
Post #93
Defo not dimma, look at my thread, dimma is more rounded and smooth not square, the dimma archs are wider and higher (as in the wide arch stops at the filler cap opposed to the one in your pic which finish much lower than the filler cap)
Posted 7th Jan 2015 at 21:59
pugheaven
Post #94
Wide track is easy at the back, the front not so much, the wishbones and shafts will be the hardest parts
Posted 7th Jan 2015 at 22:01
Twangy
Post #95
not doubting what your saying , but just looked at ice kit and is definitely not that kit
wayne mcardle
Posted 7th Jan 2015 at 22:03
pugheaven
Post #96
Its still wide so who cares Thumbs up
Posted 7th Jan 2015 at 22:06
Twangy
Post #97
back is easy , have already got pts tubular wishbones on car allread so can make wider ones and same with shafts , so no need for spacers
wayne mcardle
Posted 7th Jan 2015 at 22:09
pugheaven
Post #98
Thumbs up top mounts are easy too
Posted 7th Jan 2015 at 22:10
Twangy
Post #99
yes your right , there no problem at all ,
wayne mcardle
Posted 7th Jan 2015 at 22:13
Twangy
Post #100
thanks yours is looking awesome been following project
wayne mcardle
Posted 7th Jan 2015 at 22:22
