displaying posts 251 to 275 of 537
Pages (22): first .. 10 [11] 12 .. last
Author Subject: 306 rallye track/stage project
Twangy
Post #251
removed centre section carbon jenvey air box from moulds and bonded together ,so ready for final trim and finishing , and hopefully get fitted over weekend
Twangy has attached the following image:
wayne mcardle
Posted 20th Oct 2015 at 20:36
Twangy
Post #252
first time had chance to work on car all week ,but managed to do bit more on carbon air box this evening
wayne mcardle
Posted 26th Oct 2015 at 21:27
Twangy
Post #253
sorry picture are not that good
wayne mcardle
Posted 26th Oct 2015 at 21:28
Twangy
Post #254
starting to get there
wayne mcardle
Posted 26th Oct 2015 at 21:29
Twangy
Post #255
and 1 for good luck
wayne mcardle
Posted 26th Oct 2015 at 21:30
Twangy
Post #256
managed to sort air filter today as phoned ramair filter and sending out filter foam and backing mesh for mega cheap price , so can make to suit size I require , sending out enough to make 4 filters ,will post photos as soon as have received and made
wayne mcardle
Posted 29th Oct 2015 at 23:12
eddy_gti6
Post #257
What header tank is that off?
Posted 30th Oct 2015 at 01:32
Twangy
Post #258
it was suppose to be of ex touring car
wayne mcardle
Posted 31st Oct 2015 at 21:58
Post #259
Great work Wayne ....
Keep us updated m8 Thumbs up
Posted 1st Nov 2015 at 11:07
Twangy
Post #260
cheers Damien , finally sorted out air filter as got in contact with ramair and they supplied me with mesh cage and filter foam for a bargain price of £15 all in with next day delivery , plus was enough material to make easily another spare filter setup , so ideal for spares pack , photo is of left over caging and filter foam ,, total bargain
wayne mcardle
Posted 2nd Nov 2015 at 21:52
eddy_gti6
Post #261
Is it not? I was looking for one like that a while back
Posted 2nd Nov 2015 at 22:27
Twangy
Post #262
its ment to be m8 ,
wayne mcardle
Posted 2nd Nov 2015 at 22:32
Twangy
Post #263
carbon air box all finished now , complete with filter ,should get plenty of cold air to jenveys just a little wiring to finish and will try and get started
wayne mcardle
Posted 8th Nov 2015 at 18:48
Twangy
Post #264
with filter
wayne mcardle
Posted 8th Nov 2015 at 18:50
RallyeP6
Post #265
Twangy wrote:
started to fit throttle bodies ,and repositioned rad and oil cooler , also stripping back wiring and new fuel lines
What have you got mounted above the cam position sensor, in the engine lifting eye?.
Posted 8th Nov 2015 at 19:06
Twangy
Post #266
its 1 of the plumbed in extinguisher nozzles , has 2 in engine bay and one under dash m8
wayne mcardle
Posted 8th Nov 2015 at 19:17
eddy_gti6
Post #267
Looking good there mate Thumbs up what's that gearbox mount there you are running? BTCC spec one? What top and lower mounts you running with that?
Posted 10th Nov 2015 at 17:29
Post #268
Nice updates, wish i knew how to work with carbon, your parts look spot on! Thumbs up
Posted 10th Nov 2015 at 18:42
Post #269
Love the Carbon inlet box Wayne Thumbs up
Keep the updates coming m8
Posted 10th Nov 2015 at 20:41
Twangy
Post #270
no mate, not btcc spec one , its just one we fabricated , using wcxm mounting bush as easy to get hold of , uses sold lower back mount , and top mount has uprated rubbers with packing shims as shown in second photo
wayne mcardle
Posted 26th Nov 2015 at 20:22
Twangy
Post #271
shimmed top mount
wayne mcardle
Posted 12th Nov 2015 at 20:24
demondriverdan
Post #272
Those look good, I'm wary of the mounts in the race car. Need to learn to weld so I can do something different!
Rallye Race Car
Posted 12th Nov 2015 at 20:35
Twangy
Post #273
thanks dan , the mount work really well , get yourself a half decent mig and get practicing m8 , save yourself a fortune in future and mig would have payed for itself
wayne mcardle
Posted 12th Nov 2015 at 20:54
Twangy
Post #274
cheers Damien , thanks for all your good comments , Thumbs up
wayne mcardle
Posted 12th Nov 2015 at 21:25
Twangy
Post #275
finally had chance to prime n/s carbon door and lower back quarter were side rub strips removed , and got it painted and fitted graphics , just got to finish of fitting door back up with inner trim bits and lexan window ,
wayne mcardle
Posted 17th Nov 2015 at 20:28
