displaying posts 1 to 25 of 38
Author Subject: quick one gearbox question...
chiefton
right all bolts out everything all good
pin is out release arm but im stuck and not sure what to do about actually separating/removing the release bearing part??
any help much appreciated. thanks
cherry rallye daily (the money pit)
Posted 2nd May 2014 at 18:51
jeffers Forum Admin
Moved to correct section! Thumbs up
Iirc if the pin is out the release arm, remove the arm then ease the box off, you may need to help the release arm round so the forks disengage from behind the release bearing fork then pull the box off!
Team Running Engine again!
Team Negative Camber!
Posted 2nd May 2014 at 18:58
But sometimes the fork is a cvnt to get off some heat may be required Thumbs up
Posted 2nd May 2014 at 19:06
superchargedblack1997gti6
Yep it will be tight in there that clutch has not been changed for 40,000 miles mate? If that's out of my old black one mate?
Posted 2nd May 2014 at 19:04
jeffers Forum Admin
Where are you going to apply heat to Chris??
Posted 2nd May 2014 at 19:07
Top of the arm ? Or just bend it up to allow the fork to rotate it round
Posted 2nd May 2014 at 19:16
demondriverdan
Exactly what I did, much easier than trying to get the pin out. Once the box is off you can take the pin out if as you can spin the fork round and get the pin to an easy location.
Rallye Race Car
Posted 2nd May 2014 at 19:20
chiefton
that engine yes mate. iv got it now sorted il post up pic of damage for viewing pleasure LOL
Posted 2nd May 2014 at 19:26
Plenty of grease when putting it back together helps future removal
Posted 2nd May 2014 at 19:34
chiefton
Well this is the damage......
There is this damage on top... I dunno if it caused the failure by a bit dropping into box??
*edit* just seen the missing bit,its in the picture next to hole,so somethings blown that out
this is the diff casing inside the box...
proper job lol got couple of bits to swap then chuck it back together. Fun fun lol
Posted 2nd May 2014 at 20:32
You say a bit dropped down that hole?
Looks like that definatly caused that damage.
Seen a few threads on here where people have dropped things down that hole and was wonderjg what could happen : lol
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd May 2014 at 14:03
chiefton
Well thats what I thought but looking in the first picture the missing bit is there on top of the box.
im really not sure as to how this happened!!???
Cor what a b*stard the box is to get back in. Im sure the fork is through the bearing now so not much to do now. Is there a fill for the diff or will it fill when I fill up through the breather bit on top??
Posted 3rd May 2014 at 15:19
Looks like whatever was flying around in the hell housing smashed the bell housing causing the leak and hit the bit in the first picture breaking that bit off, that's sat on the top
Posted 3rd May 2014 at 15:24
no, more likely to be the planet gears s**tting themselves and flying about through the diff casing bouncing off the flywheel up through the top/
Posted 3rd May 2014 at 15:32
Or that lol
Posted 3rd May 2014 at 15:34
chiefton
Hmm I just cant find what caused it,,very strange unless it just smashed to bits whatever it was.
alot of metal in there lol il be hopefully finished this evening....fingers crossed cus its lovely weather and iv got a t plate toyota avensis.....boring and very boatish lol
chiefton
I reckon it was a planet gear too theres nothing else I can see that wouldve done it!!
Posted 3rd May 2014 at 15:35
chiefton
Right stuck again what have I done wrong???
the release arm bit seems to not be going back so the cable is tight and pushes the arm,the forks and the bearing were turned towards the rad when fitting?? Help please.....
Posted 3rd May 2014 at 19:02
if the pin is in the arm then you haven't got the forks behind the bearing.
Posted 3rd May 2014 at 19:06
Did you slide the for behind the thrust bearing when installing the box it's tricky to do ? If you had the fork facing the rad the it won't be right ? The fork needs to be facing the bearing cut outs so it slips in behind when the box goes on
Posted 3rd May 2014 at 19:07
chiefton
so gear box back out???
yeah I didn't mean pointing to the rad but slighty over that way then as I jiggled the box I heard it pop in and believed it to be behind the cut out in bearing..
Posted 3rd May 2014 at 19:10
Need a hand?
Posted 3rd May 2014 at 19:13
chiefton
Need a hand?
I think iv gotta leave it till 2moz now missus wants to go home you see but round 2 tomorrow ding ding lol, I may give you a shout tho mate if your about??
Posted 3rd May 2014 at 19:18
Yeah give me a shout took one out the other week. I'll try and give you a hand and get it done
Posted 3rd May 2014 at 19:20
chiefton
Sweet cheers fella il let you know Thumbs up shame cus its all back together bar that cable problem and battery box and that!!!
Posted 3rd May 2014 at 19:24
