displaying posts 26 to 38 of 38
Pages (2): 1 [2]
Author Subject: quick one gearbox question...
Easily done the lesson learned here is check before it all goes back together
Posted 3rd May 2014 at 19:31
Exactly this, you need to ensure the fork goes behind. You can actually see it through a hole in the top of the box as you slide it back on to the engine, it's kind of an experience thing but whilst it's fiddly it's not that hard.
Posted 4th May 2014 at 08:02
chiefton
Il have another crack at it later first one on a 6 iv done!!
cherry rallye daily (the money pit)
Posted 4th May 2014 at 12:03
You can check the shaft after your done putting the box back on as if it's right it will have a tiny bit of movement if it's wrong it won't have any
Posted 4th May 2014 at 12:39
chiefton
Yeah it does move like an inch maybe 2, it not too hard to move either and springs back and im sure it went in behind the cut out on the bearing!!
Posted 4th May 2014 at 13:59
An inch or two?
If it's located behind the bearing and the box is flush to the block and bolted up, there should be about 5mm movement on the fork shaft...Yes
Posted 4th May 2014 at 14:53
chiefton
Oh well the last pic ture its touching the the cable bracket and it moves back from there about an inch??
Posted 4th May 2014 at 14:58
That's not right dude you need to the box back off and try again
Posted 4th May 2014 at 15:52
isn't there an inspection hole with a plastic cover you can pop off? my 205 be3 box has one
Posted 4th May 2014 at 17:13
chiefton
Post #35
Yeah she not located correct certain iv sorted it now im just gonna try quickly.... fingers crossed
Posted 4th May 2014 at 17:32
chiefton
Post #36
all sorted yay thanks for all your help peopleThumbs up
Posted 4th May 2014 at 19:46
Post #37
I always attach the cable and try pedal before putting it all back together
Posted 4th May 2014 at 20:25
chiefton
Post #38
Yeah well I knew straight away as I moved it back it wasnt any where near the release bearing!!! What a tool...bit of a bas**rd to do on your own thats for sure!!! But flew back together after that drive lovely and retaining all oil!! Bonus Thumbs up
Posted 4th May 2014 at 20:33
Pages (2): 1 [2]
